Could you please send me prices on both hotchkis and Eibach sways for 03 coupe shipped to 46835...thanks!
Message me with any questions.
Thanks
Charles
Thanks
Charles
Message me for best deals.
Thanks
Charles
Thanks
Charles
How much are the sways for a 2007 g35x shipped to m1c1s1 Toronto Canada
QUOTE=b2autodesigns;6025379]Hello Guys,
Special!!!!! Please pm for best price
Hotchkis sway-bars 350z/g35 coupe. Lots of kits in stock:
35mm F and 24 mm R
We also have the Whiteline Swaybar endlinks in stock. Front and rear offered.
Hotchkis sway-bars 07+G35,G37 and G37S
Features:
• Lightweight, Durable 1 3/8" (35mm) Tubular Front Bar.
• Lightweight, Durable 1.063 (27mm) Tubular Rear Bar 3 Way Adjustable
• Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets.
• Finished in durable anthracite powder coat.
Benefits:
• Brings handling excitement to your G37 or G35
• Dramatically improves steering and chassis response
• Increases stability, improves traction, reduces body roll by increasing front/rear roll stiffness
• Easy bolt-on installation.
Specs:
Front Sway Bar 35mm (Ø1-3/8") Hollow
+230% Stiffer than Stock G37
+205% Stiffer than stock G37S
+230% Stiffer than stock G37S
Rear Sway Bar 27mm (Ø1.063") Hollow 3 Way Adjustable
+120, 175, 250% Stiffer than Stock G37,
+5, 30, 65% Stiffer than stock G37S
+50, 90, 145% Stiffer than stock G35S
Install instructions for G37 coupe/07+G35 sedan:
http://www.hotchkis.net/_uploaded_fi...011810file.pdf
07+G35X (AWD Model) Pm for Best Price.
Enhance the cornering performance of your G35X/G37X with a set of Hotchkis Sport Suspension sport sway bars. Our sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the car has slight under steer and limited roll control. Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary. The dreaded under steer is eliminated and the handling becomes comfortably neutral with added traction during cornering. Hotchkis Sport Suspension sway bars feature a durable powder coat finish, greasable bushings, and brackets Item# 22443 fits 08+ G35X, G37X AWD Models Only. RWD Models use item 22441 08-10 Infiniti G37X (AWD) 08-10 Infiniti G35X (AWD) Features: • Lightweight, Durable 1 3/8" (35mm) Tubular Front Bar. • Lightweight, Durable 1.125" (28mm) Tubular Rear Bar 3 Way Adjustable • Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets. • Finished in durable anthracite powder coat. Benefits: • Brings handling excitement to your G35X • Dramatically improves steering and chassis response • Increases stability, improves traction, reduces body roll by increasing front/rear roll stiffness • Easy bolt-on installation. Videos
NEW!!! Hotchkis Sport Sway Bars 04-06 G35X (AWD) PM For best Price.
Hotchkis Sport Suspension has just released a sport sway bar package for the Infiniti G35X. This sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the car has slight under steer and limited roll control. Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary.The dreaded under steer is eliminated and the handling becomes comfortably neutral with added traction during cornering. Hotchkis Sport Suspension sway bars feature a durable powder coat finish, greasable bushings, and brackets. Features: • Lightweight, Durable 1 3/8” (35mm) Tubular Front Bar. • Lightweight, Durable 15/16” (24mm) Tubular Rear Bar 3 Way Adjustable. • Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets. • Finished in durable red powder coat. Product: Hotchkis Sport Sway Bars Fitment: 04-06 Infiniti G35X (AWD)
We also offer Hotchkis swaybar rebuild kits. Comes with all 4 bushings.
http://www.b2autodesigns.com/index.p...sort=6a&page=2
Eibach Sway-Bars 03-06 G35 coupe/sedan and Eibach 07+G35 sedan/G37 coupe/sedan
Special on these. Message me!!
Reduce body roll and fine tune your g35/g37 handling characteristics with a set of Eibach Anti-Roll-Kit front and rear sway bars. These sway bars are manufactured from cold-formed, high-strength aircraft-grade steel and or sold as an entire kit or as individual front/rear kits. Anti-Roll-Kits include all necessary mounting hardware and instructions.
03-06 G35 Coupe/sedan specs: 34mm Front and 22mm Rear
Eibach 32mm Front & 29mm Rear Anti-Roll-Kit for 09-11 Infiniti G37 Sedan (Includes S / Excludes AWD) / 07-08 G35 Sedan (Includes S / Excludes AWD)
Customer feedback on Hotchkis swaybars:
Hello Charles,
The last few days ago I got the Hotchkis swaybars and RS-R springs. And I can say that I like such combination, can note the following changes:
- Improved handling.
- No longer throws from side to side when changing direction.
- Less body roll when cornering (became smoother...rear bar set in Soft).
Soon I will put a new set of tires, I hope that the grip on the turns will be better (I would like to get rid of the drift in the corners).
Once again I want to thank you for your help.
Sergey
Join us on Facebook: Always got deals going on!!!
https://www.facebook.com/#!/pages/B2...s/165793298063
Thanks
Charles[/QUOTE]
35mm F and 24 mm R
Features:
Benefits:
Specs:
]NEW!!! Hotchkis Sport Sway Bars 04-06 G35X (AWD) PM For best Price.
Hello Charles,
Sergey
Thanks
Charles[/QUOTE]
Lots in stock ready to ship. Message me with any questions.
Thanks
Charles
Thanks
Charles
Message me for best pricing.
Thanks
Charles
Thanks
Charles
