Hotchkis Swaybar kits G35,G37 and G35X Applications.
Old Jul 27, 2011 | 02:12 PM
b2autodesigns's Avatar
Hello Guys,
Special!!!!! Please pm for best price
Hotchkis sway-bars 350z/g35 coupe. Lots of kits in stock:
35mm F and 24 mm R
We also have the Whiteline Swaybar endlinks in stock. Front and rear offered.
Hotchkis sway-bars 07+G35,G37 and G37S
Features:
• Lightweight, Durable 1 3/8" (35mm) Tubular Front Bar.
• Lightweight, Durable 1.063 (27mm) Tubular Rear Bar 3 Way Adjustable
• Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets.
• Finished in durable anthracite powder coat.
Benefits:
• Brings handling excitement to your G37 or G35
• Dramatically improves steering and chassis response
• Increases stability, improves traction, reduces body roll by increasing front/rear roll stiffness
• Easy bolt-on installation.
Specs:
Front Sway Bar 35mm (Ø1-3/8") Hollow
+230% Stiffer than Stock G37
+205% Stiffer than stock G37S
+230% Stiffer than stock G37S
Rear Sway Bar 27mm (Ø1.063") Hollow 3 Way Adjustable
+120, 175, 250% Stiffer than Stock G37,
+5, 30, 65% Stiffer than stock G37S
+50, 90, 145% Stiffer than stock G35S
Install instructions for G37 coupe/07+G35 sedan:
http://www.hotchkis.net/_uploaded_fi...011810file.pdf
07+G35X (AWD Model) Pm for Best Price.
Enhance the cornering performance of your G35X/G37X with a set of Hotchkis Sport Suspension sport sway bars. Our sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the car has slight under steer and limited roll control. Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary. The dreaded under steer is eliminated and the handling becomes comfortably neutral with added traction during cornering. Hotchkis Sport Suspension sway bars feature a durable powder coat finish, greasable bushings, and brackets Item# 22443 fits 08+ G35X, G37X AWD Models Only. RWD Models use item 22441 08-10 Infiniti G37X (AWD) 08-10 Infiniti G35X (AWD) Features: • Lightweight, Durable 1 3/8" (35mm) Tubular Front Bar. • Lightweight, Durable 1.125" (28mm) Tubular Rear Bar 3 Way Adjustable • Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets. • Finished in durable anthracite powder coat. Benefits: • Brings handling excitement to your G35X • Dramatically improves steering and chassis response • Increases stability, improves traction, reduces body roll by increasing front/rear roll stiffness • Easy bolt-on installation. Videos
NEW!!! Hotchkis Sport Sway Bars 04-06 G35X (AWD) PM For best Price.
Hotchkis Sport Suspension has just released a sport sway bar package for the Infiniti G35X. This sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the car has slight under steer and limited roll control. Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary.The dreaded under steer is eliminated and the handling becomes comfortably neutral with added traction during cornering. Hotchkis Sport Suspension sway bars feature a durable powder coat finish, greasable bushings, and brackets. Features: • Lightweight, Durable 1 3/8” (35mm) Tubular Front Bar. • Lightweight, Durable 15/16” (24mm) Tubular Rear Bar 3 Way Adjustable. • Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets. • Finished in durable red powder coat. Product: Hotchkis Sport Sway Bars Fitment: 04-06 Infiniti G35X (AWD)
We also offer Hotchkis swaybar rebuild kits. Comes with all 4 bushings.
http://www.b2autodesigns.com/index.p...sort=6a&page=2
Whiteline swaybars.
32mm Front and 20mm Rear: Please pm me for pricing
Whiteline sway bars for the 350Z or G35 are available as an adjustable design, allowing you to dial in your desired front or rear stiffness. Whether you are building a time attack monster or just sprucing up your daily driver, you can be sure there is a Whiteline sway bar to suit your needs. All Whiteline sway bars are constructed from solid steel and come in "Silver Sparkle II" metallic powder coat color. Replacement polyurethane bushings, installation grease and instructions are included in each Whiteline sway bar kit. Photo may vary slightly from actual product.
Blox Racing Swaybar kits: Front 34mm and rear 21mm. Message me for best pricing.
Customer feedback on Hotchkis swaybars:
Hello Charles,
The last few days ago I got the Hotchkis swaybars and RS-R springs. And I can say that I like such combination, can note the following changes:
- Improved handling.
- No longer throws from side to side when changing direction.
- Less body roll when cornering (became smoother...rear bar set in Soft).
Soon I will put a new set of tires, I hope that the grip on the turns will be better (I would like to get rid of the drift in the corners).
Once again I want to thank you for your help.
Sergey
Join us on Facebook: Always got deals going on!!!
https://www.facebook.com/#!/pages/B2...s/165793298063
Thanks
Charles
Old Jul 28, 2011 | 01:14 PM
djfarhan's Avatar
i believe the 1st pic where the sway bars are red are eibach ones.
Old Aug 3, 2011 | 04:29 PM
Eibach Sway-Bars 03-06 G35 coupe/sedan Special on these. Message me!!
Reduce body roll and fine tune your 350Z handling characteristics with a set of Eibach Anti-Roll-Kit front and rear sway bars. These sway bars are manufactured from cold-formed, high-strength aircraft-grade steel and or sold as an entire kit or as individual front/rear kits. Anti-Roll-Kits include all necessary mounting hardware and instructions.
34mm Front and 22mm Rear
Thanks
Charles
Old Aug 3, 2011 | 09:26 PM
TorontoCPV35's Avatar
PM me price shipped to H3G 2A4, Montreal, QC, Canada?
For 2004 G35 coupe
Old Aug 3, 2011 | 10:36 PM
PM Sent
Thanks
Adrian
Old Aug 4, 2011 | 02:27 PM
gfanatic's Avatar
please pm me your best price shipped to 95747 please
Old Aug 11, 2011 | 12:44 PM
all pm sent
Thanks
Charles
Old Aug 17, 2011 | 05:33 PM
All swaybar kits in stock ready to ship. Pm me with any questions you might have.
Thanks
Charles
Old Aug 22, 2011 | 02:07 PM
Always in stock ready to ship. Fast shipping. Got a questions shoot me a pm.
Thanks
Charles
Old Aug 28, 2011 | 09:27 AM
In stock ready to ship
Thanks
Charles
Old Sep 2, 2011 | 10:57 AM
plenty in stock.
Thanks
Charles
Old Sep 7, 2011 | 02:40 PM
We have the G35 Coupe/ sedan in stock. G35 07+ Sedan/g37 Coupe in stock and the G35X 07+ Sedan in stock. Pm me with any questions guys.
Thanks
Charles
Old Sep 12, 2011 | 03:34 PM
all pm sent
Thanks
Charles
Old Sep 15, 2011 | 02:05 PM
abb2autodesigns's Avatar
Bump
Thanks
Adrian
Old Sep 19, 2011 | 11:33 AM
bump
Thanks
Charles
