Whiteline and Energy Suspension Bushings kits offered at B2autodesigns
Old Sep 1, 2011 | 12:06 PM
b2autodesigns's Avatar
Hello Guys,
We stock alot of the Whiteline bushings and Energy Suspension bushings for the G35 applications: Lots in stock
Whiteline Plus 03+ Nissan 350z / Infiniti G35 Traction Control Rear Cradle Bushing KitOne of the most noticeable compromises on the 03-06 G35 and 350Z suspension is the soft, hydraulic filled rubber rear subframe bushings that produce flex and squirm under hard acceleration and aggressive driving. To remedy this common problem, Whiteline has developed their G35/350z rear subframe bushing kit, designed around their famous Whiteline Plus series polyurethane bushings. The Whiteline rear subframe bushing kit offers 'no compromise' performance with their unique translucent black polyurethane bushings, specifically created to provide the ride quality of a rubber bushing at low speed yet offer the performance of a solid bushing when under cornering, acceleration and braking load for. These bushings will result in more chassis control and provide a more responsive, predicable and better handling Z or G. The Whiteline Plus rear subframe bushing kit replaces all four points of the rear cradle and includes all the hardware and instructions for a complete out of the box install.
Whiteline Infiniti G35/03-09 350Z Rear Diff - Mount Front & RearThe new bushing kit will help control the excessive axle tramp these platforms encounter under heavy acceleration in high horsepower applications. Whiteline’s rigoursly tested low compliance Synthetic Elastomer bushings replace the heavily worn OE front and rear differential mount bushing and dramatically reduce initial torque loss & differential movement during acceleration & deceleration.
Link to order:
http://www.b2autodesigns.com/product...oducts_id=5307
We also have the Whiteline compression rod bushings in stock.
Front Upper Inner Control Arm Bushing Kit (W52988)
Link to order:
http://www.b2autodesigns.com/advance...eywords=W52988
Front Lower Shock Absorber - Control Arm Bushing Kit
Link to order:
http://www.b2autodesigns.com/advance...eywords=W52992
Rear Upper Inner Control Arm Bushing Kit (W62989)
Link to order:
http://www.b2autodesigns.com/advance...eywords=W62989
Rear Upper Front Trailing Arm Bushing Kit (W62985)
Link to order:
http://www.b2autodesigns.com/advance...eywords=W62985
Rear Upper Rear Control (Lateral) Arm Bushing Kit (W62998)
Link to order:
http://www.b2autodesigns.com/advance...eywords=W62998
Rear Lower Rear Control Arm Bushing Kit (W62999)
Link to order:
http://www.b2autodesigns.com/advance...eywords=W62999
Rear Lower Front Trailing (Lateral) Arm Bushing Kit (W62997)
Link to order:
http://www.b2autodesigns.com/advance...eywords=W62997
Rear Lower Inner Control Arm Bushing Kit (W62996)
Link to order:
http://www.b2autodesigns.com/advance...eywords=W62996
Rear Lower Outer Control Arm Bushing Kit (W62535)
Link to order:
http://www.b2autodesigns.com/advance...eywords=W62535
Front Lower Inner Control Arm Bushing Kit (W52991)
Link to order:
http://www.b2autodesigns.com/advance...eywords=W52991
03-06 350Z & G35 Whiteline Plus Diff Mount Inserts
Link to order:
http://www.b2autodesigns.com/product...oducts_id=4493
We also have the Whiteline Swaybar endlinks in stock. Front and rear offered.
Energy suspension kit
We are now offering these by them selfs. No need to buy the whole front kit.
Energy Suspension 02-09 Nissan 350Z / 03-07 Infinity G35 Coupe Black Hyper-Flex Master Bushing Set:
Front KitEnergy Suspension 03-08 350Z / 03-07 Infiniti G35 Front Control Arm Bushing Set front arm kit includes the following bushings: Inner and outer front lower control arm, upper control arm, and compression rod! Red or black finish offered.
[B]Rack and Pinion Bushing Set:[/B ]Energy Suspension 02-09 Nissan 350Z / 03-07 Infinity G35 Coupe Black or Red
Differential Bushing Energy Suspension 03-09 350Z / 03-07 Infiniti G35 Rear Differential Bushing Set Offered in black or red finish.
Sub Frame Bushing Energy Suspension 02-09 350Z / 03-07 Infinity G35 Black Rear Sub Frame Set
Check the link:
http://www.b2autodesigns.com/product...oducts_id=4767
Lots in stock ready to ship. Pm me or call 813-787-4075 with any questions you might have.
Thanks
Charles
Attached Thumbnails Whiteline and Energy Suspension Bushings kits offered at B2autodesigns-category3781thumbmid.jpg   Whiteline and Energy Suspension Bushings kits offered at B2autodesigns-4b57554806d54578b288a6a.jpg   Whiteline and Energy Suspension Bushings kits offered at B2autodesigns-20120215150832.jpg   Whiteline and Energy Suspension Bushings kits offered at B2autodesigns-20120127163014.jpg   Whiteline and Energy Suspension Bushings kits offered at B2autodesigns-category3781thumbmid.jpg
Whiteline and Energy Suspension Bushings kits offered at B2autodesigns-4b57554806d54578b288a6a.jpg   Whiteline and Energy Suspension Bushings kits offered at B2autodesigns-20120215150832.jpg   Whiteline and Energy Suspension Bushings kits offered at B2autodesigns-20120127163014.jpg   Whiteline and Energy Suspension Bushings kits offered at B2autodesigns-group950d65cd2c3f4d1097.jpg   Whiteline and Energy Suspension Bushings kits offered at B2autodesigns-groupab8fc6cd49c74474ac.jpg
Whiteline and Energy Suspension Bushings kits offered at B2autodesigns-groupca3423890ebc4fd99b.jpg   Whiteline and Energy Suspension Bushings kits offered at B2autodesigns-b2autologo.gif   Whiteline and Energy Suspension Bushings kits offered at B2autodesigns-group950d65cd2c3f4d1097.jpg   Whiteline and Energy Suspension Bushings kits offered at B2autodesigns-groupab8fc6cd49c74474ac.jpg   Whiteline and Energy Suspension Bushings kits offered at B2autodesigns-groupca3423890ebc4fd99b.jpg
Old Sep 4, 2011 | 10:20 AM
Energy Suspension G35 compression rod bushing kit.
Link to order: $68.95 shipped this are in stock
http://www.b2autodesigns.com/product...oducts_id=5046
Thanks
Charles
Old Sep 9, 2011 | 12:04 PM
Friday bump
Thanks
Charles
Old Sep 12, 2011 | 11:07 AM
all pm sent
Thanks
Charles
Old Sep 13, 2011 | 11:16 AM
SDGenius's Avatar
do you have the Whiteline Plus 03+ Nissan 350z / Infiniti G35 Traction Control Rear Cradle Bushing Kit in-stock?
Old Sep 13, 2011 | 12:39 PM
In stock and ready to ship.
http://www.b2autodesigns.com/product...oducts_id=1206
Charles
Old Sep 13, 2011 | 01:39 PM
SDGenius's Avatar
ordered thanks
Old Sep 13, 2011 | 03:58 PM
ordered thanks
order recieved shipping today
Old Sep 14, 2011 | 02:04 AM
dineth00i30's Avatar
how much for the master kit? 2004 rwd sedan.
Old Sep 14, 2011 | 12:14 PM
Wilg35j's Avatar
How much for compression rod bushings shipped to 07055 for 03 sedan
Old Sep 14, 2011 | 01:04 PM
both pm's sent
Thanks
Charles
Old Sep 18, 2011 | 02:00 PM
all pm sent
Thanks
Charles
Old Sep 21, 2011 | 11:23 PM
all pm sent
Thanks
Charles
Old Sep 25, 2011 | 05:23 PM
Thanks
Charles
Old Sep 26, 2011 | 09:00 PM
How much ES Front kit shipped to 10310. 04 rwd sedan.
