SPC and Ichiba camber kits. BC BR Coilovers!!!
Old Mar 11, 2012 | 04:03 PM
  #91
vertigouno's Avatar
Price on SPC camber kit with toe bolt shipped to 92563
Old Mar 12, 2012 | 09:15 PM
  #92
superstarlu's Avatar
price
Originally Posted by b2autodesigns
Hello Guys.
Got these in stock ready to ship.
SPC Camber Kit
Need your SPC camber kits in a hurry. No need to worry. Free 2nd day air shipping upgrade. Get them fast!!!
After lowering the ride height of your G35. Excessive negative camber can actually hurt your traction, tire wear and cornering performance. The complete SPC Pro-Alignment front and rear camber w/rear toe kits replace the limited stock alignment adjustment and let you fine tune the handling and traction characteristics of your car. Now you can set up your ride for any driving scenario, from the street to the strip and anything in between. These kits will NOT fit cars with active steering
03-07 G35 Coupe/Sedan
07+ G35 Sedan/G37 Coupe
Front kit Adjustment range: Camber: -2.5 degrees to +2.5 degrees.
Rear kit w/toe bolt Adjustment range: Camber ±4.00 degree Toe ±3.00 degree
Please pm for best pricing.
BC BR Coilovers package's.
Mono-tube shock design
30 levels of damping force
Pillowball mounts and adjustable camber plates included*
Adjustable rear camber plates available
Separate Full length height adjustable
Inverted and Non-Inverted setups
One year warranty
Rebuildable
Technical
Coilovers use 46mm pistons and 53mm shock housings.
Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
Patented concave lower locking ring, to prevent unseating
Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 times with less than 5% deformation
T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
Iron lower brackets on MacPherson struts to ensure rigidity
Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
2 step coating process utilizing nickel and chromium plating to prevent corrosion
BR-Type
Package BC coilovers w/Ichiba rear camber kit w/toe bolt shipped $1030.00.
Package BC Coilovers w/SPC Rear camber kit w/toe bolt shipped $1079.00
Please pm me with any questions you might have. Fast shipping as always
Thanks
Charles
shippped to 53213
Old Mar 15, 2012 | 01:21 PM
  #93
b2autodesigns's Avatar
all pm sent
Thanks
Charles
Old Mar 19, 2012 | 01:50 PM
  #94
all pm sent
Thanks
Charles
Old Mar 19, 2012 | 02:52 PM
  #95
MJION's Avatar
Price check on SPC Rear kit w/toe bolt shipped to 60611?
Front and rear?
I have a 05 G35X.
Thank you!
Old Mar 24, 2012 | 04:08 PM
  #96
All pm sent
Thanks
Charles
Old Mar 25, 2012 | 04:51 AM
  #97
susu510's Avatar
SPC Front Camber kit shipped to 94539, 2007 g35 coupe
Old Mar 25, 2012 | 12:21 PM
  #98
Herbbie Hablib's Avatar
SPC front and rear camber kit to 98282.
Thanks
Old Mar 28, 2012 | 01:16 AM
  #99
Edwadowad's Avatar
Package BC BR Coilovers w/SPC Front & Rear camber kit w/toe bolt shipped to 94544 ?
Old Mar 28, 2012 | 12:22 PM
  #100
kcmacaroni's Avatar
SPC Front Camber kit shipped to 66062.. ready to order!
Old Mar 28, 2012 | 12:26 PM
  #101
all pm sent
Thanks
Charles
Old Mar 31, 2012 | 12:53 PM
  #102
bump
Thanks
Charles
Old Apr 2, 2012 | 08:19 PM
  #103
all pm sent
Thanks
Charles
Old Apr 6, 2012 | 12:40 PM
  #104
all pm sent
Thanks
Charles
Old Apr 8, 2012 | 09:56 AM
  #105
hdmark's Avatar
Price shipped to 18069 for spc front and rear with toe bolt and BC br true coil over design.
Thank you
