ModBargains.com | KW Coilovers Variants 1, 2 & 3 l Best Deals Period !!!
Old Feb 15, 2012 | 01:46 PM
ModBargains.com's Avatar
ModBargains.com is proud to present to the G35/G37 community KW Coilovers Variants 1,2 & 3 !!!
Call in today for the ABSOLUTE LOWEST PRICE on all KW Coilovers. Give me a call at (714) 582-3330 ext 8003 or ask for Frank for the special price !!
Applications:
  • 350Z (Z33) Coupe + Convertible 03-09
  • 370Z (Z34) Coupe + Convertible 09+ **
  • G35 Coupe 2WD (V35) 03-08
  • G37 2WD 08+ **
** = KW V2 N/A
About KW Coilovers
Is your Vehicle looking a little too high? Do you still feel insecure about the sharp turns you attempt around the corners? Is your current body kit not doing the job of creating that AGGRESSIVE appearance? Treat your vehicle and yourself with the best suspension system out there--KW's Coilovers! Not only does this system lower your car perfectly, but it provides HUGE performance benefits.
KW designed and manufactured every coilover to CUSTOM fit your vehicle, unlike other coilovers that may be a "special one-coilover-fits-all", guaranteeing MAXIMUM handling and performance for your vehicle. Along with handling, this system makes sure your car is given a perfectly AGGRESSIVE stance, not a vehicle that's touching the floor. Maybe you're not the one for aggressive looks and ultimate performance, but for comfort. Well, KW took that into consideration, and integrated adjustable comfort technology.
KW is known for their signature colors, individuality, quality, and security. Take a look below to read more into which KW Coilover Variant is the BEST option for you!
KW Variant 1
Sportive - Harmonic with KW factory pre-set up dampening
The ideal systems for customers wishing to rely on the experience of KW engineers, yet determine their own degree of lowering. In extensive driving tests our engineers have set the dampers for the best balance between sporty driving, comfort and safety.
- Optimally adjusted, sporty and comfortable dampening technology
- inox-line stainless steel technology at no extra charge
- Individually height adjustable
- German TUEV-tested lowering range
- High-quality components for long life
- Comprehensive documentation for ease of us
KW Variant 2
Sporty and Personalized with adjustable Rebound Dampening
The system intended for the experienced driver who requires to not only determine the individual lowering of their vehicle, but adjust the damper setting to fine tune the system to their needs. The adjustable rebound damper allows adjustment of the pitch and roll behavior of the vehicle, adapting it to one‘s own driving preferences.
- Damping technology with individually adjustable rebound
- inox-line stainless steel technology at no additional charge
- German TUEV-tested adjustment parameters
- Comprehensive documentation for ease of use
- Infinitely adjustable rebound damping
KW Variant 3
Race Technology for the Road with: Adjustable Compression Rebound Dampening
The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the high speed set-up, so decisive for driving comfort, has been preset by our engineers
- Independently adjustable damping technology -rebound and compression damping
- Individual height adjustment
- 14- level adjustable compression damping
- Unique, independently functioning damping power adjustment
What are Coilovers?
A coilover suspension basically gives you a matched lowering spring and shock absorber combination with the added benefit of adjustable ride height and spring rates through a moveable spring perch or perches. Coilovers are to your car's advantage by reducing unsprung mass, increasing suspension travel, and allowing the car to be corner balanced.
Why do KW's cost more than other Coilovers?
The answer is simple, you get what you pay for when it comes to vehicle suspension. As such a crucial component of your vehicle, suspension is definitely something you do not want to cheap out on. KW is known for their reinforced and durable suspension components. KW's coilovers have been carefully crafted and designed by studying the flaws of competitors and improving on them. In addition KW coilovers can go lower than just about any other brand and allow you to set your car to a "slammed look", "sporty look", or anywhere in between. In the unfortunate event that anything should happen to your coilovers, KW's warranty backs all their products from manufacturer's defect.
Function
Infinitely adjustable within German TUEV-tested adjustment parameters
Shortened struts for increased spring travel
Trapezoidal threads for simple height adjustment
Three different damping technologies for individual adjustment
Elastomer bump stops with integrated dust boot protection
Easy to read documentation
Ready to use comprehensive solutions
Visually perfect – safe and unique motion dynamics
Quality
Strut housings in inox-line stainless steel technology
Anodized aluminum spring collars and add-on pieces
High-quality, high-tensile racing springs
Special ventilation and sealing system
High-quality damping components
Hardened, chromium-plated piston rods
Special guide and sealing systems
Pistons with V-shaped Teflon seals – optimal sealing with minimal friction – temperature-resistant, durable damping technology
Any questions feel free to call me at (714) 582-3330 ext 8003 or e-mail me at Frank@ModBargains.com
Old Mar 7, 2012 | 07:19 PM
Keep those PMs coming! Thanks guys!
-Frank
Old Mar 14, 2012 | 07:27 PM
More inventory in stock and ready to ship!
-Frank
Old Mar 22, 2012 | 09:46 PM
More KWs in stock!
Old Mar 23, 2012 | 06:21 PM
gang unit's Avatar
04 g35 coupe V1 or V2 shipped to 01540 please.
Old Mar 28, 2012 | 07:18 PM
PMs replied!
-Frank
Old Mar 30, 2012 | 05:34 PM
PMs replied
Giving out great discounts daily - give me a call at 714 582 3330 ext 8003.
-Frank
Old Apr 6, 2012 | 08:01 PM
KWs come with a lifetime warranty - just one of the many reasons why KW are the best choice for coilovers.
-Frank
Old Apr 13, 2012 | 07:55 PM
Got more kits in! Send those PMs!
-Frank
Old Apr 17, 2012 | 05:23 PM
More kits in stock!
-Frank
Old Apr 17, 2012 | 05:27 PM
PAIXAO's Avatar
KW V2 2004 sedan 6mt shipped to 20745
Old Apr 17, 2012 | 05:33 PM
You got PM!
Old Apr 17, 2012 | 11:15 PM
ssmuong's Avatar
KW V2 2006 coupe 6mt shipped to 98034?
Old Apr 18, 2012 | 08:12 PM
PM replied!
-Frank
Old Apr 26, 2012 | 02:00 PM
More kits are in stock - send me those PMs for the best pricing!
-Frank
