BC Racing Coil Over Kit For 350Z/370Z/G35/G37 Setup *** $999 or $1199 Install (NY)
Old May 26, 2012 | 12:55 AM
RAVSPEC's Avatar
BC Racing Coil Over Kit For Infiniti G35/G37/M35
$999 shipped or $1199 Install
SWIFT custom spring options available with this package.
*** Add Assist Spring / more comfort ** Front Only - ($150.00 Extra)
Any questions, don't hesitate to email us !!
Assist or Helper springs which install on top or bottom of your current coil over spring. It helps increase comfort or increase performance on your current coil over.
Assist springs
Assist springs have two functions. The first is the spring adds a progressive rate to the initial portion of the stroke. This progression can add increased comfort is used on a daily driver coilover setup that has stiff springs installed. It provides racers added softer spring rate progression. Once the assist crushes, the normal spring rate will take over.
The second job is the same as helper springs. They prevent the loss of traction during rebound, and extreme cornering.
Assist springs are designed to repeatedly be fully crushed. Every assist spring crushes to the same height. That allows drivers to change assist springs without resetting the spring perch on coilover without changing ride height.
Helper Springs
Helper springs prevent dismounting of springs from perch on coilover
without changing spring rate.
Swift helper springs are specially designed to provide minimal effect on spring rate. Using helper springs allows the spring to stay firmly on its perch when the shock has negative or zero load. Driver should use helper springs if they experience springs coming loose from their perch and/or they can not preload the main spring because of car height issue.
Old Jun 6, 2012 | 08:24 PM
bnice113's Avatar
Where in NY are you located
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
HypedAndy
Aug 18, 2015 03:34 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
