Digital Torque Wrench Special !!
Old Jul 2, 2012 | 05:13 PM
blmw's Avatar
As a new vendor on this forum, we are offering an introductory special: our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: g35
You can see the torque wrench in action in the following video:
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid until August 1st, and is only for the lower 48 states.
Old Jul 12, 2012 | 11:03 PM
blmw's Avatar
Need a torque wrench? Here you go!!
Old Jul 16, 2012 | 05:19 PM
blmw's Avatar
15 days left! Don't miss out.
Old Jul 17, 2012 | 11:53 PM
bdeitemeyer's Avatar
Maybe I overlooked it, but what's the warranty on this? Thanks.
Old Jul 18, 2012 | 09:58 AM
blmw's Avatar
Our warranty is industry standard: 1 year from date of purchase, 90 days for calibration. We have a repair / calibration facility in Chicago in case anything does need to be done to the wrench.
BLMW
Old Jul 31, 2012 | 04:52 PM
blmw's Avatar
Tomorrow is the last day! Get one while you can.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
