HKS Hipermax Coilovers G37 Coupe
Old Aug 28, 2012 | 04:59 PM
Coz@Czp's Avatar
G37 Coupe 08+ RWD HKS Hipermax lll Coilovers
With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS' all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time. In addition, the Hipermax III is shock-body adjustable (most applications) to allow vehicle height adjustment without affecting spring rate and piston stroke. With the Hipermax III’s range of adjustability, precise corner balancing can be achieved. Chrome-plated cylinder shafts provide excellent durability and newly-design rubber upper mounts reduce harshness
37
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases.
• Strengthened rubber upper mounts – enhanced durability • Monotube design
• Shock-body length adjustable (most applications)
• 65mm diameter springs – Cold wound and manufactured in-house at HKS to ensure quality and consistency. 8k/9k Spring rates
• Stainless lock nut & ride height adjuster – feature anti-rust & corrosion characteristics for enhanced durability.
• 30-way adjustable dampening
• Hard chrome-plated cylinder shaft
• Non-electrolysis Nickel plated shock bodies provide durability in severe weather conditions.
• Pillowball upper mounts optional on certain applications
• Dustboots standard
• 1 year limited warranty
Special 25% off for forum members.
Old Sep 25, 2012 | 02:09 PM
Coz@Czp's Avatar
Thread Bump!!!
Old Oct 3, 2012 | 04:56 PM
Coz@Czp's Avatar
Thread bump!!
Old Dec 11, 2012 | 01:24 PM
Coz@Czp's Avatar
Thread Bump
R350k5
Oct 1, 2015 08:41 PM
MikeTanabe
Brakes
Aug 26, 2015 03:02 PM
newg37
Jul 26, 2015 09:32 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
