SPC Camber kits - Front, Rear, or Both
Old May 3, 2016 | 11:18 PM
Tolboothwilley™'s Avatar
<h1 style="text-align: center;">350Z/G35 FRONT ARMS (PAIR) <br />Part #'s: 72123/72050</h1>
<p style="text-align: center;"><br /><span>350Z &amp; G35 Front Upper Control Arms (pr) - 72123</span><br /><span>350Z &amp; G35 Rear Camber Kit - 72050(x2)</span></p>
<p style="text-align: center;"><span><strong><span style="color: #ff0010; font-size: x-large;"><span>Note:</span><span>&nbsp;ONLY 1 Kit Needed Per Car</span></span></strong></span></p>
<p style="text-align: center;">--------------------------------------------------------------------------
-<br />This popular adjustable upper control arm/shim kit has been re-designed to match the SPC *family of Nissan and Infiniti arms. Our new *tubular design has reduced weight by 1 pound per arm and increased rigidity. SPC's arms are the only 350Z arms on the market that can get +3.5&deg; to -1.5&deg; camber change. Additionally, you will be able to set your caster at &plusmn;1&deg;. This patented design makes camber and caster adjustment easy using the sliding and rotating ball joint. The kit includes everything needed, including the ABS sensor bracket, shims, and the adjustable arms.&nbsp;</p>
<div id="ds_div">
<div style="text-align: center;"><strong><span style="font-size: large;">Brand new in the box, 100%AUTHENTIC</span></strong></div>
<div style="text-align: center;">Package come completed with front and rear, both sides</div>
</div>
<p style="text-align: center;"><strong><span style="color: #ff0000;">FITS:</span></strong><br /><strong><span style="color: #ff0000;">2003-2009 Nissan 350Z</span></strong><br /><strong><span style="color: #ff0000;">2003-2007 Infiniti G35 Coupe</span></strong><br /><strong><span style="color: #ff0000;">2003-2006 Infiniti G35 Sedan</span></strong></p>
Other suspension parts here: Infiniti G35 Suspension Parts
<p style="text-align: center;">&nbsp;</p>
<div id="ds_div" style="text-align: center;"><strong>SPC Alignment Components - Control Arm:&nbsp;<br /></strong>*ADJUSTABLE CONTROL ARMS*<br />These fully adjustable Upper Control Arms transform your classic Mopar from sluggish, non-responsive handling to high performance FUN! Dial in additional positive caster, adjust your camber, and enjoy the feel of up to 6 degrees adjustment! Arms include stock ball joints. Sold as individual arms. Ball joint are often included (check Item Notes for specifis).<br /><br />*TUBULAR CONTROL ARMS*<br />These arms lower your front end by 1" and add 1&deg; positive caster for an aggressive, ready-to-run stance. Optional Ride Height Tuning Kits are available for use with our Pro Series Springs or 'standard type' springs to raise the ride height if desired. If you have coilovers use our Coilover Mount and Spacer Plate.&nbsp;<br /><br />*TOE ARMS*<br /><br />*CAMBER ARM*<br />For specific vehicles this tubular style arm is great when lowering this popular vehicle, or for correcting rear camber on stock vehicles.<br /><br />*CLEARANCE ARMS*<br />These extreme lower control arms are for Performance Vehicles. Made from aircraft aluminum alloy, these arms are available in a silver, blur or red finish. When teamed up with front and rear camber arms SPC Performance provides you with a complete alignment solution when lowering your car.<br /><br />*LOWER CONTROL ARM*<br />These arms fit for your ride, giving you a range of camber change. Great for popular tuner vehicles, these machined parts are in a stand-out silver anodized finished with SPC &ldquo;Red&rdquo; nuts.</div>
<div id="ds_div" style="text-align: center;">&nbsp;</div>
<div id="ds_div" style="text-align: center;"><strong>SPC Performance</strong>&nbsp;is your source for performance suspension tuning parts and tools. Whether you have a slammed RSX, spend the weekends fine tuning your circle track racer or can't wait to put another coat of wax on your '72 Camaro, we can give your ride a true advantage with optimal tracking and handling in professional chassis set ups.</div>
Old May 10, 2016 | 07:36 PM
bump
Old Jun 25, 2016 | 08:17 PM
FYI: SPC new updated rear camber arms are not bent - they are straight, but still replace the bent OEM arms
