need help
Old Dec 11, 2007 | 09:53 AM
rob350's Avatar
Exclamation need help
im trying to find a front camber kit. who is a good option to go with. i thougth kinetix but i found on this forum that they suck and they bend and flex but people put them upside down. anyone have there 2cents on kinetix a-arms? i can't afford stillen or 350evo there in the $800+ range. cusco and eibach, spc make a-arms any 2 cents on these brands. help!!!!!! wow! nobody like kinetix's products.
https://g35driver.com/forums/g35-coupe-v35-2003-07/125841-my-kinetix-arms-they-about-break.html
https://g35driver.com/forums/wheels-tires/97792-kinetix-camber-kit-review-pics.html
https://g35driver.com/forums/showthr...ber+kit+review
Old Dec 11, 2007 | 10:00 AM
huyrua's Avatar
Check SPL, they make quality suspention parts for the Z and they are located in Austin. I'm thinking going up their soon to buy some parts.
Old Dec 11, 2007 | 10:17 AM
pabg35's Avatar
Simple Ax6 G
350evo are supposed to be the best, but you could go with spc through th motorsports
Old Dec 11, 2007 | 10:18 AM
FastDontLie's Avatar
...we dont need roads...
I told you this maaaan!! SPC
Old Dec 11, 2007 | 10:25 AM
rob350's Avatar
^daniel im just asking.
what about spl?
http://splparts.com/main3/main/default.htm
in the first diagram pic where are those pieces located?
https://g35driver.com/forums/suspension-vendor/187384-___-spc-camber-kit-front-rear-holiday-blowout-save-your-tires-___.html
Old Dec 11, 2007 | 10:42 AM
G Thizzle's Avatar
spc
Old Dec 11, 2007 | 11:56 AM
rob350's Avatar
well kinda leaning with daniel's idea "nitto neo gens."
Old Dec 11, 2007 | 01:57 PM
Jason@Riverside's Avatar
Personally I would only install a front camber kit to get MORE negitive camber...
If you want to save tire life, get tires that are directional only... once you see tire wear on the inside, take them OFF the rim and flip them and remount them on the oposite side...This will put the INSIDE on the OUTSIDE and you will get twice as much wear...
Must less expensive then a camber kit, you will still have good turn in and less understear then if you put less negitive camber...
Old Dec 11, 2007 | 02:17 PM
venommaxr33's Avatar
Must Go Faster!!
good call Jason
Old Dec 11, 2007 | 02:29 PM
OH6 G35's Avatar
++1
Old Dec 20, 2007 | 01:06 PM
waijai's Avatar
i.love.gold
I have a Top Speed camber kit, which is the same as the Megan Racing front A-arms. Let me know if you're interested.
Old Dec 21, 2007 | 12:58 PM
G35_TX's Avatar
SPL
https://g35driver.com/forums/showthread.php?t=125841
https://g35driver.com/forums/showthread.php?t=97792
