Lowering Spring and rear struts
Old Mar 25, 2009 | 08:01 PM
G Thizzle's Avatar
very easy install... devon you still got my spring compressors?
Old Mar 25, 2009 | 10:53 PM
ATX350's Avatar
Boo, I'd stay in help since I've done it a few times but going to Austin for the Acura RSX state meet. Good luck with install.
Torque specs:
Old Mar 25, 2009 | 10:59 PM
ATX350's Avatar
And for some bathroom reading:
http://www.carbibles.com/suspension_bible.html
Old Mar 25, 2009 | 11:34 PM
Sick Z's Avatar
Team 210 VQ'Z
Where you at Eric?
Old Mar 25, 2009 | 11:35 PM
ATX350's Avatar
@ work until 1am. Am I suppose to be somewhere?
Old Mar 26, 2009 | 07:58 AM
wnt1bd's Avatar
"devon you still got my spring compressors" Yes sir.....we have done spring install so many times now....easy job
Old Mar 28, 2009 | 08:48 AM
wnt1bd's Avatar
Today is CANCELED!!!!!
Old Mar 28, 2009 | 05:31 PM
SA Z-ster's Avatar
yay......we should do it on tuesday because im off
Old Mar 28, 2009 | 06:16 PM
Hustlekid03's Avatar
dont take offense to this but..........who are you????
Old Mar 28, 2009 | 07:16 PM
SA Z-ster's Avatar
If I told you you wouldnt remember me....It been a while since Ive been out. Names Jason by the way, have a white z
Old Mar 28, 2009 | 08:11 PM
FastDontLie's Avatar
...we dont need roads...
Are you the one that got chris's old wheels?
Old Mar 28, 2009 | 08:23 PM
SA Z-ster's Avatar
yeah that would be me.....they dont look so hot any more due to my accident.
Old Mar 31, 2009 | 02:54 PM
SA Z-ster's Avatar
Need some 210 VQZ help. Well I went to get get my alignment done and I was told that I need a left front camber and a new tie rod......I know I need a new tie rod but Im wondering if their is anyway I can get one of you guys to take a look at it for a second opinion. They printed me out the measurements from the alignment. The left side is where I got in my accident.... Any help would be greatly appreciated. Thanks
Old Mar 31, 2009 | 08:31 PM
wnt1bd's Avatar
On thje fronts of our cars....we dont have much correction avalible to us without going aftermarket, but if you need a new tie arm that will correct the problem because you need to do an alignment after a tie rod is installed.....in a perfect world......since you are out of alignment are you pulling eiother way left or right....if not is it just toe? If its toe you will get wear on inside or outside of tiers....if ots alignment you will get uneven wear patches or cupping.
You might want to look at a camber kit if you are out of wack....but before that get you tie rod replaced....again pretty easy install, but you will still need an alignment.
Old Apr 1, 2009 | 12:47 AM
  #30
SA Z-ster's Avatar
Yeah I might be getting a rod soon from another member, but if anyone has one let me know. I was even looking at the tein rod but I think a stock one will do. As far as the pull the car would pull to the left and both tires wore down fast. One wore out on the outside and one wore out on the inside. I had them align one side to somewhat correct the alignment. Thanks for you help.
P.s. let me know if you guys got any spring installs going on this week.
jsimonk
Dec 22, 2023 03:49 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
Th611
Oct 27, 2015 03:48 PM
wuppiedog
Aug 7, 2015 11:16 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
