help with vdc
Old Jan 9, 2008 | 09:08 PM
thejayman's Avatar
Lightbulb help with vdc
has anyone found a way to bypass the traction control on the base model Zs? i looked for a fuse to pull but there isn't one in the fuse box next to the battery. any ideas...?
Old Jan 9, 2008 | 11:16 PM
Sick Z's Avatar
Team 210 VQ'Z
I thought base Zs dont have VDC OR TCS. But if you do have it you should have a switch to turn it on and off by your gas door switch.
Old Jan 9, 2008 | 11:45 PM
thejayman's Avatar
i didnt think so either but every time i try to get the car sideways some type of traction control sets in. i have been reading up on the yaw control sensor under the center console and how bypassing it with a switch can shut all traction assists off but keep the abs functional. i found this in another section...
There is a thread in MY350Z http://www.my350z.com/forum/showthr...?threadid=85956
Here is a qoute from there
"Disconecting the Bosch Yaw sensor under the center console (below e-brake) will disable bothe VDC/EBD without disabling the ABS! "
Here is how for 350Z and G35 coupe
"1. Remove key from ignition
There are 5 screws to remove on the Z (only 4 on the G35C)
2. First two screws are on either side of console towards the rear, it helps to slide both seats all the way forward, and tilted to access these.
3. Next screw is under the ash tray (lift up) (the G35C does not have this one)
4. Next you will need to pull up gently on the shifter boot plastic cover... I do this by sticking my hand in the leather boot and pulling up until it clicks in a few places. (You do not need to remove the shift ****)
5. You should now see the last two screws below holding the center console in place. (Be carefull not to tear the electric ribbon for the heater controls on the Z and there is one electrical plug to unplug on the G35C if you have heated seats).
6. With the center console lifted up over your e-brake handle (pull the brake up high to make it easier to remove the center console) you will see there are two sensors: The one towards the rear is for the airbag (DO NOT DISCONNECT THIS ONE) The one towards the front (directly behind the shifter) is a black sensor with BOSCH sticker. This is the one you should un-plug. The clips for the plug are on either side of the connector. Secure the loose connector to avoid future rattles.
7. Replace center console reverse of removal.
Enjoy the much improved throttle and brake response of your car! " "
Tell me what you think...
Thanks,
g4ian
anyone else hear of or have experience with this? im kind of hesitant to try it.
06g35
Feb 14, 2022 05:59 AM
Thebaws11
Nov 30, 2016 12:54 PM
MThawkins86
Oct 24, 2015 02:07 AM
markbilo
Sep 30, 2015 01:33 AM
