TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Question for Rev up 6mt owners
Old Feb 16, 2008 | 11:20 AM
lewie145's Avatar
I just got a 06 coupe with the 6mt, the car has 10k miles on it. I was wondering if this is normal. In pretty much every gear especially noticeable in 3rd and 4th around 2-3k rpm when I floor the gas, the revs jump up about 1k rpm and then the engine kicks in about a second later and the rpms drop back down. Is this normal? Basically it feels like im riding the clutch, but I do not have the clutch pushed in at all. It feels more like an automatic than a manual. I have owned a lot of manuals and liked manuals for the simple fact that when you hit the gas the car goes. It does not take a second for the engine to kick in. Also I turned the VDC off because I thought that might be the problem, but noticed no difference at all. I also thought it might be traction issues but that is not possible because I have tested it in 3rd 4th and 5th at like 50 miles per hour and it does the same thing everytime.
Old Feb 16, 2008 | 11:24 AM
dream_G35's Avatar
sounds like you need a new clutch
Old Feb 16, 2008 | 08:50 PM
lewie145's Avatar
Is it possible to get a clutch replaced if there are only 10k miles on the car??? I know it is a wear and tear item, but surely it should last more than 10k miles.
Old Feb 16, 2008 | 08:59 PM
caelric's Avatar
Sure, it's possible, if the previous owner abused the clutch. The symptoms you described are classic symptoms of needing a new clutch. Might want to go aftermarket at this point, not that you need an aftermarket clutch, but it might be cheaper, and will be stronger.
Old Apr 9, 2008 | 12:03 AM
06CoupeDaddy's Avatar
Good luck with that one! I've been told under NO circumstance will Infiniti pay for a new pressure plate and/or friction disc even if the car only has 100 miles on it!!!!!!!!!
Back last year I had the dreaded problem where the pedal would stick to the floor and they replaced the clutch master cylinder (ignoring the slave cylinder all-together), whereas I'd replaced the entire system. Back then the clutch was slipping BAAAAAAAAD when this would happen, sometimes to the point of smoking, and a number of times (not all the time) it would at
Long story short, the master cylinder fixed the problem as far as the clutch pedal staying on the floor, or half-way up. But the damage was already done to the disc itself.
Fast forward... I go in a few weeks ago and spoke with them about it never being the same since it was smoking the clutch last year and although I'd learned to just baby it but it slips EVERY SINGLE TIME you try to get down on it with VDC off. There is no way around it, put power to the ground like the car is meant to be driven (not RACING, just spirited driving) considering our cars ARE TRUE 2+2 coupes and should indeed be able to withstand maximum throttle runs here and there. Making SURE that I stressed we're not talking about doing burnouts here, just getting traction off the line and gunning it through the gears. (Which I've been doing for over 40 years now (having another dreaded B-day tomorrow) as I started driving a clutch in my Dad's 63 Econoline work van when I was 9. And YES I have a very thorough grasp on how to drive a stick.)
The dealership I use is and has been very good to me so I'm not complaining about them per say, just repeating what I was told. And that was, "Infiniti will NOT approve a clutch replacement under any situation at all. (As it applies to the drivers use I was told.)
The story that went with that statement was a lady came in with a car that se bought the day before, with 90 miles on it claiming it was burned up and slipping. Which INDEED it was according to the Service writer. He said he rode with the lady and she was the type that would feather the clutch at a stop, even on a hill, rather than pressing it in and using the brake to hold the car at a stop. None the less, even under the 12 months/12,000 miles bumper to bumper, THEY WILL NOT REPLACE THE CLUTCH!
Needless to say I was a bit miffed. He went on to say that it's considered like tires and brakes. Actually went as far as to say you can get the brakes replaced easier than the clutch. (I'm assuming you'd need to show that a caliper was sticking which isn't all that rare for a piston to get a little cocked in the bore.)
He did tell me I could bring my own clutch in and they'd provide the labor. NO FREAKING $HIT! "In fact we have had a number of guys doing upgrades to lighter flywheels and new clutches that we've done that for.", was his statement. "Just bring it in, we'll be happy to do the clutch and exhaust all at one time if you want." OH yeahhhhhh.... end up paying more for labor than I would for the clutch assembly, springs, sways AND exhaust! Me think's not.
tiguy99
Mar 1, 2016 11:42 AM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
Srinidhi
Aug 7, 2015 03:38 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
