TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Problem Please help: Not Shifting
Old Jun 4, 2008 | 11:28 PM
ZigZag's Avatar
2003 G35 auto sedan. I was wondering if anyone has experienced any problems where the car goes into a limp mode. It wont shift. I just got the transmission replaced with a used transmission, because the dealer said it was the valve body. Codes didn't clear after the replaced transmission was installed. Any suggestion? What was the actually problem when it was going into limp mode from the beginning? Could it be wiring or a sensor? Ive spent $2700 and i still don't know the problem. Help!!!!!
Old Jun 4, 2008 | 11:31 PM
express705's Avatar
why wouldnt they just replace the VB?
Old Jun 4, 2008 | 11:35 PM
ZigZag's Avatar
No warranty plus vb was the same price as the transmission and they thought the transmission could have been damaged.
Old Jun 4, 2008 | 11:37 PM
express705's Avatar
hahah well your own little mistake for taking a used transmission. if it wasnt shifting, anyone knows the first place to look on an auto is the VB....
Old Jun 4, 2008 | 11:38 PM
ZigZag's Avatar
so your saying i bought another transmission with the same problem????
Old Jun 4, 2008 | 11:41 PM
express705's Avatar
no, im saying that you replaced a perfectly good transmission.
your valve body is most likely the problem. i suggest you request that your dealer change it, as they are stupid not to diagnose the problem correctly.
Old Jun 4, 2008 | 11:45 PM
ZigZag's Avatar
Is the valve body an internal part on the transmission? Sorry for the basic question.I have the feeling its not
Old Jun 4, 2008 | 11:46 PM
express705's Avatar
if you drain the tranny fluid, take off the tranny pan, its RIGHT there.
cant miss it.
big ugly peice of **** that my car HATES>
Old Jun 4, 2008 | 11:48 PM
ZigZag's Avatar
So would i not get a working one with a different transmission or is it not even a part of the transmission?
Old Jun 4, 2008 | 11:49 PM
express705's Avatar
i would call tomorrow and see if you have your origional or a new one..
i have no idea what they did, but from what you posted and from what i understand, you still have the bad VB if it even is the VB.
Old Jun 4, 2008 | 11:53 PM
ZigZag's Avatar
with the replaced transmission would i not get a different vb with that?
Old Jun 4, 2008 | 11:55 PM
ZigZag's Avatar
ill call tomorrow. Thanks for your help.
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
cmesidewayz
Sep 29, 2015 09:28 PM
Jnm07
Sep 5, 2015 01:16 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
kevintandmd
Sep 3, 2015 06:41 PM
