TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Temperature Guage (overheating? maybe)
Old Jun 28, 2008 | 11:14 AM
Duritskoy's Avatar
Since cali has pretty high temperature last week (105-108) when i turned on my AC i saw my temperature guage go up like 2 of those lines, it never went more than that. Is this normal since it was hot and i was going around 75. Im jus scared that it might over heat my car.
Anyone had this problem ? if not anyone have any solutions for it? it happened twise. after that it hasn't gone up at all.
thx in advance
-Kelvin
Old Jun 28, 2008 | 11:18 AM
TheDude's Avatar
it was 102-103 here a week or so back and my gauge never moved.. may be getting too hot but I don't know.
Old Jun 28, 2008 | 01:21 PM
nghiars's Avatar
What year is your car, how may miles? Have you ever had a radiator fluid flush? thermostat goign bad? Basicly, we need more details.
Old Jun 28, 2008 | 04:20 PM
Duritskoy's Avatar
2006, 6MT 50k miles, and no i havent had my radiator fliud flushed. the thermostat? im not to sure whats that but every sensor is working fine.
Thx for the replies guys.
Old Jul 3, 2008 | 02:48 PM
tglag35's Avatar
Do any of you guys know what is the proper way to have a radiator fluid flush on infiniti cars?
Old Jul 6, 2008 | 02:26 PM
RBull's Avatar
Rated M
thx in advance
-Kelvin
Don't worry about it. It was very hot out and you were demanding highway speeds and AC. If the gauge went up a line or two during this period it's nothing to worry about as long as in cooler temps it has come back down. If not it's possible you're down a bit of coolant or there may be slight blockage in the system somewhere, although it's doubtful.
Old Jul 7, 2008 | 07:10 PM
Karma's Avatar
You can't flush out your cooling system at home. All you can do is drain about 60% of your coolant from the rad, and change it.
If you want a complete fluid change, go to a Mr Lube or similar and get them to do it.
We have all heard the horror stories about those type of lube places, but its really your only choice.
Old Jul 8, 2008 | 03:06 PM
SE2002's Avatar
Im having this similar issue again. My cars temp is reaching way to high...close to overheating 75% high. This only happens when the A/C is on and i am in a stop and go traffic, idling for a while or on the regular road. On the freeway is ok and fine. My A/C starts to get warm and muggy and the temp rises. When i turn off the A/C my temp gauge goes back to normal. This happened before and I did a radiator flush and replaced the thermostat. It worked fine afterwards. Could this had happened again because of the heat here in socal..freakin 108+ lolz?? My mechanic said the thermostat was bad before..did the thermostat go out again?? or could it be something else? How can i check?
Old Jul 8, 2008 | 03:11 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
+1 your fine koy...
G35Rican
Jul 31, 2024 01:37 AM
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Jay123
Sep 28, 2015 08:42 PM
mattdg35
Sep 14, 2015 11:28 AM
