TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
New owner of 05 g35 Sedan-need help
Old Nov 17, 2009 | 03:49 PM
Msgoody2shoos's Avatar
New to this thread- bought an 05 g35 in August, with 56k miles. A month and a half ago the airbag light kept coming on (blinking constantly), I tried resetting it and it will go away for a little while but come back within 24 hours. About a month ago the tire pressure warning light came on. I checked the tire pressure (has all 4 new tires) and the tire pressure is OK. The light seems to come on only in the morning when it's cooler and when I make a right turn. Weird! Then by the afternoon when the weather warms up the light is off! Lately it has been happening every single morning. Now I have BOTH the airbag light blinking and the tire pressure warning light. I called Infiniti and they seem to think it is a sensor that needs replaced but they can put it on the machine for $125 to find out for sure (plus the cost of parts). Anyone else have this problem or know what to do? Should I take it in to the dealership? Help!
Old Nov 21, 2009 | 03:59 AM
umair's Avatar
airbag should be under warranty so i dont know why they would charge for that... the guy i bought mine from said the same thing about the airbag and they didnt charge him to look and fix it but then again he might have known the tech...
tire pressure light will almost always come on when it is cold out! i keep a pump in my car just in case as ive blown a tire before by not payin attention to the light bc the tires "looked" fine... i would imagine sensors are bad bc it doesnt make sense for it to be going on and off without you actually messing with the air pressure...
all else fails... go to NISSAN if you can as INFINITI will be more expensive
Old Nov 22, 2009 | 07:42 PM
dspec35's Avatar
air bag is definately warrenty
about the tpms if its blinking
i would first make sure you have the air pressure set above 30 psi
at the dealership where i work we set all to 38 psi
see if that helps if you still have the blinking issue then most like the tpms need to be initialized i'm sure that will fix it
question for you though have you ever had a flat tire and used fix a flat if so you will need a new tpms
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
vstypicals
Jul 20, 2015 10:55 PM
Chattzx
Jul 17, 2015 11:23 AM
