Whose done a TS reflash
Old Oct 21, 2006 | 05:15 PM
Jtrain's Avatar
I'm going to start building my engine a little bit with cams and heads, I'm running a Unichip right now-- but I'm assuming I'll probably want a TS reflash so I can rev higher correct? Theres no way to change the limiter with just a unichip?
How much is it, how do go about doing it, how long does it take etc.... and is it worth it.
Old Oct 21, 2006 | 05:44 PM
g35rcr's Avatar
why dont you go to the same place that did your miracle tune...
Old Oct 21, 2006 | 05:49 PM
Jtrain's Avatar
They ran out of cheeto power *******
blow me-- Be ****ing useful or dont post
Old Oct 21, 2006 | 05:51 PM
g35rcr's Avatar
well post your dyno and i would be more than happy to help you...
Old Oct 21, 2006 | 06:38 PM
Paperchaser's Avatar
dam ...already
Old Oct 21, 2006 | 06:43 PM
sjc1789's Avatar
Florida G35 Club
i thought about a TS reflash for a long time.. and then i just went with a utech... u can change ur rev limiter and alot more with it.. and u can tune it urself and make changes as u change ur mods.. unlike the TS flash u have to have it reflashed with new mods to be most effective.. go with the utech.. or if u want to go all out go f-con pro.. but thats alot of money.. i went with the utech..
Old Oct 21, 2006 | 06:45 PM
G35DORME's Avatar
"It’s never enough”
Well that was quick LOL
Old Oct 21, 2006 | 07:16 PM
Calvin's Avatar
Overglorified Altima
next day your ecu to them with a list of all your mods. let them reflash it. tell them to next day it back to you. your g will be don for two days. cost is about 495.
that is..if memory serves me correctly..
or if youre in socal then just drive to them
edit: might wanna try a search next time this thread just started a few days ago
https://g35driver.com/forums/reviews/121834-ts-custom-reflash.html
Old Oct 21, 2006 | 07:53 PM
Derek173's Avatar
I am not a fan of the mail in flash, your car needs to be put on a dyno so you can pull numbers like A/F ratio and go from there. Thats why I chose the utec. You can have 5 seperate maps, plus you can set it to 0 to have it run stock map. Then when your done you can always sell the utec unlike the reflash.
http://turboxs.com/more_info.php?ID=217
you can get one for around $750
Old Oct 21, 2006 | 11:35 PM
Jtrain's Avatar
Should have gotten the utec instead of the unichip then huh...?
I really just want to increase my rev limiter
Old Oct 21, 2006 | 11:45 PM
sjc1789's Avatar
Florida G35 Club
the utech is great.. 5 different fuel maps.. stand alone ignition.. and alot of other things like rev limiter.. the best thing about the utech is that you can tune it yourself..
esotericrider
Feb 14, 2022 07:19 AM
manh3
Aug 14, 2017 12:24 PM
Joe Gargano
Sep 18, 2015 11:17 AM
04Gcoupe
Tuner & Dyno
Nov 27, 2005 12:24 AM
Nismoboy
Forced Induction
Apr 9, 2005 03:23 PM
