Do i need a reflash?
Old Sep 15, 2007 | 06:18 PM
ExclusiveAutoDetail's Avatar
I am driving an 06 Automatic G35 Coupe with the following performance mods:
Fast Intentions Exhaust
5/16 iso thermal Spacer
Stillen CAI
Z-Tube
Also, power does not seem to be equal throughout the shifting. It feels jerky at first, fine in the midrange, and the top-end takes a while to kick in.
What do you guys think? Do I need the reflash and will I see some big differences? If you have the Technosquare, please give me your opinion.
Old Sep 15, 2007 | 06:46 PM
suicidesam's Avatar
****defected****
nah...imho i don't think you need one. if you had the 5/16 spacer with a m-rev2, headers after market cats and a cat back then i would consider getting one. may i suggest a grounding kit for your 5at it does make your shifting points better.
https://g35driver.com/forums/questionable-posts/167140-custom-grounding-kit-engine-bay-pic.html
Old Sep 15, 2007 | 07:13 PM
really? is there anything else i need that i can improve performance
Old Sep 15, 2007 | 07:25 PM
App6MT's Avatar
Littering and...
MREV2 with the spacer will work wonders. Also look into test pipes and/maybe headers.
Gord's Grounding kit after that and I would look towards UpRev for a reflash.
Old Sep 15, 2007 | 07:31 PM
Still2Slow's Avatar
A reflash would probably help some, maybe an 8-10whp gain would be possible. I would wait and finish out your mods and then go with a reflash after you're all done with mods.... at least for a while. If you eventually plan to go FI, then I would think about purchasing some type of engine management that could be used with the FI application later down the road, and not waste your money on a reflash.
Old Sep 15, 2007 | 07:32 PM
terps's Avatar
reflashes on NA usually dont net you any more power, but they will make u quicker from your wallet being alot lighter
Old Sep 15, 2007 | 08:07 PM
OCG35's Avatar
not true. I've had 2 TS reflashes
First TS re-flash bumped rev limiter, opens throttle plate all the way at WOT and adjusted A/F after several breather mods...
Second time adjusted A/F when I was running lean after installing HFC
Both times resulted in significant gains.
Old Sep 15, 2007 | 08:18 PM
Skaterbasist's Avatar
Retired SuperMod
Like Mike (OCG35) said, thats not true.
Besides, the purpose of a flash is to get that AFR back to the ideal mark [and adjust timing]. If it yields power, great. If it doesn't, well, it still did its job.
Old Sep 16, 2007 | 12:10 PM
fortified's Avatar
It is almost essential for exhaust changes. And opening the throttle plate and bumping the rev limit is a nice bonus.
Old Sep 16, 2007 | 12:27 PM
empfl's Avatar
just curious.. where can you reflash? i'm about to get some headers/HFC/spacers.. and recently got HKS Hi Flow installed..
Old Sep 16, 2007 | 12:30 PM
PSD G35's Avatar
^^good question. I was wondering the same.
Old Sep 16, 2007 | 01:53 PM
_jb's Avatar
_jb
Photographer
Think about getting UpRev's Osiris to flash your ECU.
Tell UpRev what mods you have and they create a ROM file that you flash to your ECU with Osiris. When you get new mods, tell them and they'll make a new ROM file so you can flash your ECU with the new mods.
After you get Osiris, use the included Cipher software to log the air/fuel ratio, timing, and other things to get a real customized ROM map to flash to your ECU. It's all included in the price of Osiris.
Old Sep 16, 2007 | 02:42 PM
OCG35's Avatar
Go the Shawn Church's dyno day next Sat (there is a thread in the So Cal regional forum)... another option is Technosquare in Torrance.
Old Sep 16, 2007 | 09:15 PM
terps's Avatar
sorry, TS has a good reflash from what I hear, however in my area there a questiona
'reflashes' where there no gains and it is questionable if a reflash even occurred.they also push reflashes for EVERYTHING. I would try an ecu reset and see if that solves the prob.
Old Sep 18, 2007 | 05:16 PM
Deathmage's Avatar
people who say you don't need a reflash with those mods are on crack.. you prolly get a modest power gain, but more importantly, you'll get a safer a/f. exhaust mods will lean out your a/f and reflash will fix that. also, it'll bump your rpm to 7200 up top. you should get a testpipe first though and maybe be a lightened crank pulley. forget headers.. too much of a hassle. plus if you want to go fi later, you'll have to dump it..
esotericrider
Feb 14, 2022 07:19 AM
manh3
Aug 14, 2017 12:24 PM
Joe Gargano
Sep 18, 2015 11:17 AM
04Gcoupe
Tuner & Dyno
Nov 27, 2005 12:24 AM
Nismoboy
Forced Induction
Apr 9, 2005 03:23 PM
