Dyno numbers - stock vs stillen airbox, stock vs mrev
Old Aug 19, 2008 | 12:50 AM
BolivianFuego's Avatar
Here is basically the same graph i posted above, the 219whp figure but at a 0' smoothing setting....
It still isnt as rough as his at 0'.
Old Aug 19, 2008 | 12:52 AM
N/A Project's Avatar
-2006 IP GT350-
I'm glad that I am still running stock 06 air box here.
I think stock 05 and 06 air box has velocity stack in it.
Thanks for the testing.
JJ
Old Aug 19, 2008 | 01:48 AM
DaveB's Avatar
Trey-
As usual, great analysis and thanks for the taking the money and time to do this. While I don't think everyone will see a 6whp/wtq drop adding the Stillen CAI, I think it's just more dyno proof that intakes don't do squat for these cars and also seems to kill the notion that tuning can take advantage of making power with aftermarket intakes.
Old Aug 19, 2008 | 11:48 AM
Hey trey! Could you possibly send me the before and after dyno run files? Like the two last runs you posted up? Run 5 and Run 3? Did you get a file copy of those? Or are these just print outs the place gave you?
Old Aug 19, 2008 | 01:10 PM
trey.hutcheson's Avatar
When I finished up the post, I knew there was one more comparison that I was forgetting. I just remembered: stock plenum with stock airbox versus mrev+ plenum with stock airbox. Sure, I already covered that one, but my basis was the tuned versus untuned.
So here is a chart that shows the dyno from a week ago, with the stock airbox and mrev+, compared to last week, with the stock airbox and stock plenum. Both untuned, so to speak. The blue curve is the stock plenum, the red curve is the mrev+.
First, it's interesting to note that the stock collector is running richer after 4400rpms. Second, you can see that after 3200, the mrev+ is definitely making more torque, until the two lines cross at ~5300. From there, it's all the stock collector.
Up top, the difference is much larger. At 6500rpms, the difference is 14.5hp in favor of the stock collector. At 6900, it's almost 22hp. When the numbers are crunched for the "drag strip rev range", the stock collector beats out the mrev+ to the tune of 3.22hp/1.01tq. Not huge by any means.
Now the new configuration(stock collector) does not fare as well when compared to my baseline a year ago(mrev+). But like I've mentioned, my tune is effectively gone right now.
Old Aug 19, 2008 | 01:24 PM
Sure thing. Here's a zip file that contains all 27 pulls that I have performed on that dyno. Inside the zip is an excel file that has a description of each pull.
File Type: zip
Old Aug 19, 2008 | 03:31 PM
Q45tech's Avatar
Factory engineers use ENDOLENE CLEAR as reference fuel to avoid weekly, daily, monthly changes in pump gasoline. Not unusal for pump fuel to vary +-5% in btu per gallon without ethanol, make that +-8% with E10.
Dramatic difference between winter [higher btu] and summer blend [starts May 1-15].
Old Aug 19, 2008 | 03:40 PM
I'm sorry, but I'm afraid I don't get your post. That totally seems like a bot's post.
Are you suggesting that the discrepancies in my dynos can be explained via differences in fuel? If so, then that might be a part, but I can't speculate on how large of a factor that might be.
Old Aug 19, 2008 | 04:01 PM
redlude97's Avatar
Trey, do you know if your stock intake box has the small or large velocity stack?
Old Aug 19, 2008 | 04:04 PM
Large. I think. By looking at the pictures, it appears to be the larger of the two. However, I don't have an 03/04 against which I could compare.
Old Aug 19, 2008 | 04:08 PM
redlude97's Avatar
I'm guessing all revup engines have the larger velocity stack, just trying to confirm
Old Aug 19, 2008 | 05:04 PM
Derzigster's Avatar
My 05 6MT coupe has the larger one. I checked this weekend when I cleaned the filter.
Old Aug 20, 2008 | 08:58 PM
FairLadyZ_manne's Avatar
lol i switched my mrev to stock 06 rev up collector today.
it took like an hour
we'll see trmw if it makes a difference
i am also going to put on a crank pulley also
i also put on my stock 06 box with a fresh k&n filter lol
Old Aug 29, 2008 | 10:53 PM
Iceman00's Avatar
I pointed this out on my350z a while ago, and just recenly others have caught on
Why spend so much money going backwards?
Check this for a nice comparison:
http://my350z.com/forum/na-builds/36...up-mrev-2.html
Old Sep 1, 2008 | 03:59 PM
  #30
Q45tech's Avatar
Measure the btu per gallon of the fuel used as that will directly control BMEP [the amount of peak pressure on the piston] and that is torque.
Engineers use pressure sensors between spark plugs and heads to measure BMEP.
http://www.optrand.com/products.htm
The point is so many variables with any dyno impossible to accurately use it to compare tiny differences in products +-2% or +-6 HP or lb/ft.
