Osiris Standard questions
Old Mar 9, 2009 | 06:28 PM
oxmis's Avatar
hey guys I was wondering when you get the osiris standard and set up your maps does it reflash every time you switch maps or is it just reflashed based on the number of maps you have
Old Mar 9, 2009 | 07:42 PM
_jb's Avatar
_jb
Photographer
Reflash loads all your maps into the ECU's memory.
Switching maps just moves a map from memory to the current/active map.
You only reflash once, unless you get a retune or different/new maps.
Old Mar 9, 2009 | 08:22 PM
oxmis's Avatar
so 1 reflash is equivalent to say 4 maps?
Old Mar 9, 2009 | 09:00 PM
_jb's Avatar
_jb
Photographer
The ROM file that gets flashed to your ECU contains all of your maps.
Old Mar 9, 2009 | 09:02 PM
oxmis's Avatar
cool so im not necessarily reflashing everytime I switch maps
Old Mar 9, 2009 | 09:25 PM
_jb's Avatar
_jb
Photographer
Nope.
The ROM file (including all your maps) gets flashed to the EEPROM in your ECU once. The maps are always available after that... Until you decide to change them.
Old Mar 9, 2009 | 09:30 PM
oxmis's Avatar
cool thanks bro
Old Mar 18, 2009 | 06:31 PM
ska12's Avatar
how much horsepower should i have if i have a vortech, 600cc injectors, walbro, 2.87 pulley, 1/2 motordyne plenum spacer isothermal, and a uprev tune?
Old Mar 18, 2009 | 10:33 PM
UpRev's Avatar
1 Billion.
Thats impossible to answer, your motor will make what it will make. The tune will only make it more or less efficient and more or less safe.
Frankieg35
Mar 20, 2016 09:42 PM
mrxkenny
Aug 17, 2015 05:52 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Red G Coupe
Tuner & Dyno
Jul 30, 2015 08:32 PM
