Took my 03 5AT sedan to the dyno again...much better than before.
Old May 19, 2009 | 01:29 AM
gabe3d's Avatar
Look at this, hehe.
They actually don't look like this anymore since I wrapped them last week. So long for the liquid titanium look
Old May 19, 2009 | 01:33 AM
03threefiftyz's Avatar
big time teaser.......where did you get them from?
Old May 19, 2009 | 01:36 AM
Jeff92se's Avatar
Red Card Crew
Originally Posted by gabe3d
You might be able to get an Osiris. My car (1st batch of g35coupe to come to US) couldn't get flashed with the Uprev software, so he downloaded something off my car's ECU and sent it to Uprev. The next day they were able to create a ROM that allowed my car to get flashed.
Do you know exactly what they did? ie.. ecu model number? etc.? I'm an early sedan also and would like to hear from someone that had the same problem. I wasn't aware that the coupe had the early ecu problem
Old May 19, 2009 | 01:39 AM
Too the best of my knowledge the uprev/osiris works with all coupes. The only car that it is not compatible with is the early 03 sedans. Since you have a coupe you should be fine. The reason it only effects the sedans is because they used the early pin out style from the maximas to get them out and running early. Any Uprev tuner should have all necessary means to flash your coupe.
Old May 19, 2009 | 01:49 AM
gabe3d's Avatar
I have no clue as to what he did other then him connecting to my OBDII port and starting up the UpRev software. I can ask him this weeks to see what he did, hopefully this will help you guys obtain the power of Osiris (or at least a little closer)!
PM me in two weeks. I will have before and after dynos with the headers on, it's gonna be on a Dynojet LC series, but remember that I already have some aftermarket headers that are crap but equal lengths nonetheless.
Old May 19, 2009 | 01:51 AM
gabe3d's Avatar
I see, so it's actually a connector issue, not a software one. In that case then, it looks like my experience is useless in this context.
Old May 19, 2009 | 01:55 AM
Well.....I believe its both. The ecu used in the pre 03 nissans is just an older generation. I am by no means an expert, but I know that there is an actual, physical difference b/w them that makes them incompatible with the osiris flash set-up. Bed time, later folks.
Old May 19, 2009 | 08:46 AM
GT-ER's Avatar
UpRev said there is no solution for early 03 ecu's other than cutting the stock harness and installing a modern ecu or simply using a piggyback ( which is what I'm gonna do ).
Old May 20, 2009 | 01:04 PM
Iceman00's Avatar
Rev up manifold with a spacer will help push your powerband to the right.
Old May 20, 2009 | 01:21 PM
GT-ER's Avatar
peak power is already near redline so I think I rather push the redline more to the right. I'll see if I can post a pick soon.
Old May 20, 2009 | 01:43 PM
GJ Hazlett's Avatar
Would rev up manifold help that much on a 5AT?
Old May 20, 2009 | 02:31 PM
No. The rev-up plenum was designed overly aggressive. It really won't add any extra power (maybe 2-4whp on the very top end). If you are already holding near peak power to redline you will not see any benefits. All it will do is cut down on low-mid range power (perhaps even significantly). On some built DE's, people are swapping over to the rev-up because it flows more and can support power past 6500 rpm.
Old May 20, 2009 | 04:37 PM
GJ Hazlett's Avatar
That is what I thought and was suprsied to see it mentioned for the AT.
Old May 20, 2009 | 08:00 PM
OCG35's Avatar
I don’t understand how a 3” MAF housing is going to make any difference without a bigger TB, bigger diameter induction tube, boring of the intake runners in the plenum & manifold – and probably porting the heads… Just putting a bigger MAF housing with same sensor and changing nothing else shouldn’t make a difference. The gains you saw from the tune would have probably been the same with a standard 2.75” (or whatever size it is) MAF housing.... What am I not understanding?
BTW – to the Osiris on early 03 issues… UpRevs cable connector doesn’t work with the real early 03s ECU connector… very, very few cars have this problem… most 03s are fine – only the very early cars (purchased in 2002) will be a problem.
Old May 20, 2009 | 08:04 PM
  #30
OCG35's Avatar
if you are making power past 6300 without cams that’s an anomaly... the non revup DE peaks almost 500 rpm before stock redline
