Another Osiris tune before/after
Old Oct 29, 2009 | 07:36 PM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
Just to add to the database of Osiris tune results...
Car is a 2006 6MT G35 coupe. I have a few bolt on mods, which I'll detail later. Tuned by Church automotive in Socal. I won't get into the "but their dyno reads high issue." I'm just looking at the gains.
FWIW, my 2003 5AT coupe dynoed 278 there at one point, and in the same configuration, dynoed 258 SAE corrected at another shop's dynojet.
Out of interest, I added data that I had from another stock revup that ran on their dyno a few years ago. I'm pretty happy with the gains, and for $550, it's probably the best bang for the buck mod that I've done. 17.5 horses at peak and 22.77 gain at around 6200. I exported the data into excel so that I had a easier time comparing the runs.
Most of the gains were made with adjustment of the intake cam timing. Pretty much no change adjusting the exhaust cams and air fuel ratio. However the engine is smoother.
Mods are:
JWT popcharger filter with Stillen intake box
Grubbs one piece intake tube (incorporates the MAF housing).
Slightly bored TB
polished upper and lower NON revup plenum with mild porting, everything port matched from TB to intake side of heads.
Crawford headers, jet hot coated
XYZ Y pipe
3" Japtrix B pipe
UR crank pulley
Engine is a V2 replacement for oil consumption, with approx 13K miles on it.
Running stock cats and stock muffler with a reducer cone going into the stock muffler.
Old Nov 4, 2009 | 12:33 PM
ttrank's Avatar
Grocery getter
Old Nov 4, 2009 | 11:39 PM
Tollboothwilley's Avatar
what is a japtrix b pipe?
Good gains. Looks like you know Dave from nissan sport mag..based on your mod list.
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
AJC128
Nov 1, 2015 11:55 AM
Usman Ali
Oct 4, 2015 08:23 PM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
