Fspec and Lspec technosquare reflash
I have a 2003 g35 sedan im looking to get a reflash from technosquare, but im just looking for people have it already and can share some experiences. I wanted to know what kind of gains you got and if the difference in price between the Fspec and Lspec is worth it. Thanks
For the price of the Technosquare flash which is pretty much cookie cutter tune just like Cobb I would opt for Osiris which you can datalog and have Uprev send you a tune specific to your car
IMO, it's an old tech option, but it's one of the few opens for the early ECU G35. Are you sure you have the old ecu? You should call up your dealer, tell them your VIN and ask them for your ECU code. Then call up Uprev and figure out if yours is compatible.
^^^ yes... only the early 03 wont accept Osiris... the connector is different - if you can get under the driver side console and see yours, I think there are pics (of the connector that does work) to compare it to - check UpRevs site (not positive they have pics there, but they might... look in the pdf manual too).
Or as previously stated you can determine by VIN
esotericrider
Feb 14, 2022 07:19 AM
emilepmartin
21
Mar 10, 2004 07:43 AM
