Reflash from Auto to Manual trans ECU?
Oct 2, 2012 | 10:40 PM
I was told the ecu can just be reflashed from auto to manual trans. I tried doing this with the consult II but it pulls the vin and realizes that is not the right program for the car and will not go through with it. Is there anyway to do this? My problem is I keep getting codes from the ecu because it is not hooked up to the auto trans thus I can't pass emissions and get a plate. Please help.
Reply 0
Oct 2, 2012 | 11:00 PM
It would have to be with uprev, shoot me a PM I might be able to help you out
Reply 0
Sep 2, 2019 | 01:56 PM
04 g35 coupe manual swapped with a a/t motor
Quote: It would have to be with uprev, shoot me a PM I might be able to help you out
Hey i need some help is it possible i need to reflash my ecu it came out the same year g35 and all just automatic im assuming my car has the manual ecu still in it ? Car starts most the time but will idle at 3-500 rpms and then when i step on the gas all the way it will gonk right out
Reply 0
Sep 2, 2019 | 03:02 PM
So you just swapped in the ENGINE from an automatic, everything else stayed the same with your car? Should run fine.
Reply 0
Sep 2, 2019 | 03:14 PM
Yes
Quote: So you just swapped in the ENGINE from an automatic, everything else stayed the same with your car? Should run fine.
but let me get this straight itll run to 500 rpm.if i hold the gas midway but as soon as i throttle it itll bog out instantly
Reply 0
Sep 2, 2019 | 03:15 PM
And
Also starter fluid helps it go up rpm but wheb i gas it itll bog out instantly ? Hmmmm
Reply 0
Sep 2, 2019 | 03:20 PM
Take it to a competent mechanic
Reply 0
Sep 2, 2019 | 03:32 PM
Quote: Take it to a competent mechanic
At this point around my area i cant trust them they ruined my starter and i had to get a new one just tryna see if this expensive obd reader cant read my car but read the otber 2 next to me that tells me ecu issue with communicating cause also when i step on throttle to rev it not only it bogs out but fuel pump.primes off
Reply 0
Sep 4, 2019 | 03:57 AM
UPREV has a new feature from Auto to Manual swap to turn the automatic transmission specs off the ECU. They did it for my friends G35 with a manual VK56VD.
Reply 0
Nov 29, 2020 | 05:12 PM
2004 g35 coupe
i need the same help i wanna tun a auto computer on my manual car i guess my computer fried already what should i do to make my computer work
Reply 0
Nov 30, 2020 | 11:45 AM
We can do it as part of an Uprev tune, costs $600+ tho
Reply 0
Dec 16, 2020 | 03:11 AM
Quote: We can do it as part of an Uprev tune, costs $600+ tho
Hey Seymour, just wondering if there was other way to contact you regarding tunes since I cannot PM yet with a new account on the forum
Reply 0
Dec 16, 2020 | 11:39 AM
Email me, seymore4@gmail.com
Reply 0
Mar 10, 2021 | 06:31 PM
Quote: UPREV has a new feature from Auto to Manual swap to turn the automatic transmission specs off the ECU. They did it for my friends G35 with a manual VK56VD.
I’ve just completed swapping from 5AT to 6MT in an 04 Coupe. The only thing swapped was the Transmission so the ECU and engine are all stock 5AT. PNP, Cruise Control, Reverse, and Neutral switches are wired up. The car starts and runs. I’m just looking to get rid of that pesky “Check AT” light that flashes. I do have the UPREV tuner license, but I’m having a hard time finding the feature to swap from Auto to Manual. Is this something that is only done with the “Pro Tuner” features or am I just blind?
Reply 0
Mar 10, 2021 | 06:48 PM
Only protuners can do it
Reply 0
