Need Help For Ecm/Ecu Wiring!!
Old Oct 29, 2012 | 12:44 PM
tle.88's Avatar
I just removed the Split Second piggyback from my 2003 G35 coupe, manual. Going back to stock. The previous owner tap/wire it into the stock ecu so I didn't do it in the first place to start from there. I use this web page to rewire it http://www.superchargersonline.com/i...20-010v6.0.pdf. Should be page 16. So what I did was just ran the engine sensor wiring to the factory ecu terminal wiring straight across. Is that correct? I don't hear the fuel pump whining/priming, it crank but don't start.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
BfloG35
Oct 16, 2015 05:22 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
