osiris questions
Old May 17, 2014 | 06:58 PM
DragonBoas's Avatar
osiris questions
A friend of mine has the osiris tuner version and he's getting rid of his Z so I might buy it from him. I've never used osiris but since it is the tuner version can I use it on multiple vehicles since I have 2 G35's?
Also for the one is it even worth it or should I just keep looking for a haltech, perfromance mods are as follows:
HKS exhaust, berk HFC, Injen intake, motordyne spacer, 660 injectors, 255lph fuel pump, lightweight flywheel, and twin disc clutch. It was supercharged but took that off for twins, now have most of a tt greddy setup but until I get the other pieces I need it is still sitting. Once the TT is on will I even be able to use the osiris or would that be out of its range? Also it is a 6mt if that makes a difference.
If I could use it to tune multiple vehicles that would be awesome since the other one is an AT and desperately needs a tune if for nothing else but to get rid of the check engine light from the test pipes. Also has motordyne spacer, intake, and borla exhaust so maybe I could get something out of it.
Any help is appreciated.
Old May 17, 2014 | 07:20 PM
Urbanengineer's Avatar
It will say if the license on cable is one or two. Odds are it's just one. Tuner means you can adjust it yourself. Much more desirable but not necessary.
Old May 17, 2014 | 07:28 PM
DragonBoas's Avatar
Ok, so I would still need another license for the second car? How much is a second license, can't find it on uprev's website.
Old May 17, 2014 | 09:23 PM
DrewDrew's Avatar
300
its clearly listed under their engine management tab.
Old May 17, 2014 | 11:42 PM
DragonBoas's Avatar
Ya I noticed that after. Wasn't reading properly. Still a little out of it after surgery.
Old May 18, 2014 | 12:00 AM
seymore4's Avatar
m56
The only cables that can hold more than one are the special protuner cables that are available to Uprev certified pro tuners. They are not for sale. Tuner version cables come with 1 license, but you can reload another one on to the cable once the first one is flashed off (transferred onto an ECU). You can use the tuner version cable to tune an unlimited number of cars, but each additional vehicle will need another license ($300).
OP feel free to PM me if you've got any questions about how it works, or if you need to pick up another license
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
