exhaust leaks
exhaust leaks
Is there a dye available that can be introduced into the throttle body to identify exhaust leaks? For instance, something similar to the compressed air can with a straw used for seafoam?
Here's something you could try if you don't have a smoke machine.... shop vac and windex. I've never had to resort to something like this because my exhaust leaks were always really obvious and I could find them by ear or by feeling for the exhaust with my hand at cold start.
https://www.youtube.com/watch?v=fXiQn7OW-3Y
I'm unable to raise my car to a height enough to inspect the upper portion of my exhaust headers. This is why I would like to use smoke through my throttle body.
Does anybody know someone in the San Jose - Sunnyvale, California area who would let me work on my G35?
You can actually see a lot just by using a bigger inspection mirror and a good flashlight. I'm fairly confident I could ACCURATELY smoke test my coupe with it sitting in the parking lot if I had to. Everything exhaust under the car is very accessible, headers you could inspect from the engine bay.
Just make sure you do it on a calm day, no wind whatsoever. No need to bust out a Kestrel, if you can feel wind or see any plants waving around it's too windy for accurate smoke testing. Lighting a wooden match is a good way to test wind as well since you can watch the smoke coming off of it, if there's enough wind to disperse the smoke from a wooden match then you will probably have a hard time finding it leaking from the exhaust.
