Altered Atmosphere reflash results
Old Apr 22, 2006 | 05:31 PM
JZ39's Avatar
I had my reflash done today. Unlike the last two days that I dyno'd, the conditions today were poor--warm and very humid. The results showed good gains in the middle portion of the curves, however, the results seem very inconsistent with my last dyno before headers.
Here is the breakdown (all numbers are SAE corrected):
HP TQ Date dyno performed Humidity
Baseline, no mods: 232 228 March 4 2006 6%
+Stillen catback, spacer 243 234 March 16 2006 6%
+ Alphawerks headers 247 226 April 22 2006 42%
+ Reflash 249 233 April 22 2006 51%
Now,based on the butt dyno, there is no way that the headers made only 4hp and lost 12TQ!!! The car felt so much faster after the headers I couldn't believe it!
Here are the graphs from today showing only the last two conditions. You'll see pretty good gains in both HP and TQ from 3500-6000, but we weren't able to gain anything up top. Also, my A/F ratios were totally different today then on either of the two previous dyno days (on those days I was running incredibly lean, up to almost 17:1 at points, but today the baseline run was almost flat at 14:1! WTF?
Basically, I am not confident in the continuity of the dynos, however, you can clearly see the gains from the reflash today.
Old Apr 22, 2006 | 05:36 PM
bwassul's Avatar
Are you going to go back for a re-dyno?
Old Apr 22, 2006 | 05:42 PM
JZ39's Avatar
Nah, I am not wasting any more money on dynos. We did a bunch of dynos today with different tuning maps and it is what it is.
The proof is in the 1/4 mile results at this point.
As I said, I am not confident in the continuity of the dyno from day to day because these day-day results were simply too odd.
Old Apr 22, 2006 | 06:02 PM
JZ39's Avatar
Oh yeah--the other variable could be the gasoline that is being distributed right now.
As you all know, they are taking out the MTBE (or whatever it is) and replacing it with ethanol. From what I understand, MTBE is better than ethanol for power and efficiency and when the two are mixed, as might be the case at this particular time of year as the switch over is being made, supposedly the mixture is worse than either of the two alone.
Old Apr 22, 2006 | 06:51 PM
Sundeviljay's Avatar
dyno's suck
Old Apr 24, 2006 | 06:55 PM
bosssho's Avatar
How was everyone at Altered Atmosphere to deal with? I am looking at them vs. Technosquare in CA. Any info would be appreciated.
Have you been to the drag strip...b/f or since all the work?
Thebaws11
Nov 30, 2016 12:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
9tray turbo
Sep 29, 2015 10:22 PM
Joe Gargano
Sep 18, 2015 11:17 AM
