ipod integration working properly?
When I park my car overnight, or at work, I leave my iPod connected and just turn the car off and go inside.
Sometimes when I return to the car it will be playing XM or a CD, then a few minutes into my commute switch over to the ipod source but not play anything.
I have to go down into the view of the ipod controller that doesn't have my climate control settings and select a playlist to get it to start playing something again.
Is this normal? Am I supposed to disconnect and turn off the iPod when I go inside? I'm just tired of listening to a good song on XM or CD then have the iPod just pop up out of no where and have to navigate down into it to start playing a song.
I have mine pulgged in overnight and it comes back on immediately when I start the car, playing where it left off. Sounds like yours is shutting down completely, then once it powers back up it takes over again. I suspect it has more to do with the iPod than the integration. Mine is one of the old, old ones that has the small monochrome screens, so it does a few things differently than the newer models.
yea, mine's an old mini that died for a while but i wiped it and it is working again.
does the ipod stay on while the car is off, thus draining the battery till it's turned back on.
my ipod is a 4th gen 60gb ipod photo.
I didn’t try it yet cause I didn’t get Ipod...but If you plug the Ipod in the AUX connector (Vid/Aud under your arm...I dunno what they call it lol) and press the AUX Button....can u play music and videos that you stored?
Guys, I think the OP's car is the 08 model with INTEGRATED IPOD control. I know when I put the iPod thorough my 07's AUX port, it'd still run even if I turn off the engine... Well, I only use CF card now anyway...
