Hey -- resurrecting this for an update -- loaded a Froyo build on to my rooted Droid (CyanogenMod 6.0RC1) and the bluetooth issues I was having went away. So if you're stock, the 2.2 update should fix the problems. If you're rooted, go get CM 6.
anyone find a way to transfer the contacts yet? I got an EVO myself
Quote:
huh?Originally Posted by B T
This is all hear say, I have no intention of pairing with this so called "Droid"...
Quote:
Originally Posted by Jayhawk815
huh?
His Screen Name is B T... get it? BT - Pair with droid. NyukNyukNyuk
I just got a Samsung Galaxy S - aka Captivate on AT&T.
BT paring is easy, no need to switch back to handset then back to car, no static.
Also, was able to send my entire phone book just by "select all" in the contacts app, then send via BT. works very well. Took awhile, but I have a lot of contacts. The only downside was that the phone itself, when sending via BT, lists EVERY contact. This means it shows sim and phone contacts. you can't filter them. You can only select-deselect. This basically makes sending all useless, since you'll have duplicates.
Still, not that big of a deal.
I guess we have different contact apps, the evo one is an HTC app if Im not mistaken
Quote:
Wow. I was little slow on the uptake on that one.Originally Posted by dookie
I have first gen Droud Sync for the BT was simple . Chech phone setting my 11 year old granddaughter could do it
my hero used to work, now it doesnt. I will dial and it connects just fine, but i cannot hear anything from the other person. I have paired and unpaired multiple times. I have tried resetting the phone a few times and have not had success. Anyone else with a hero have any issues. If you have connected, maybe help me out a bit? Cant wait to get rid of this slow phone.
