07 G35 Sport - Is it possible to add the rear backup cam?
Old Nov 13, 2010 | 02:21 AM
blkcamarozr28's Avatar
Question 07 G35 Sport - Is it possible to add the rear backup cam?
Any DIY'ers out there that installed the stock rear backup camera after getting their cars? What is needed and the costs? Thanks!
Old Nov 13, 2010 | 09:28 PM
terrycs's Avatar
I don't think has never been done. There are several threads that discussed the topic.
Old Nov 13, 2010 | 10:07 PM
kool_yaar's Avatar
^+1, i think it would be costly since you would need the camera, the new chrome spoiler and the harness and then route the wire to the screen, i think the Aftermarket backup camera options are cheaper and easier.
Old Nov 15, 2010 | 07:08 AM
RemmyZero's Avatar
you can do the stock camera for fairly cheap actually (i was going to do this) but keep in mind you will need either a PAC VCI interface or use it through the aux inputs. you will not be able to see the directional lines on it as you would if it came from the factory.
i have a stock camera sitting in my basement, debating on whether i should put it in this spring upcoming.
Old Nov 15, 2010 | 04:03 PM
terrycs's Avatar
Aftermarket cam is a piece of cake going through the aux input. Having a fully functional stock one is not so easy.
Old Nov 16, 2010 | 06:14 AM
borderline's Avatar
You'll need the camera, the steering sensor, all the wiring not present and a video signal box. That would cost a lot of $$. What I will do if I was you is to install an aftermarket cam and get a wireless (receiver/transmitter) unit.
As TERRYCS said, you plug this into the AUX input under armrest. This is what I will do when I receive the camera I ordered. I already have the chrome trim and the cam is supposed to fit in there.
Old Nov 16, 2010 | 07:09 AM
RemmyZero's Avatar
one thing to note though, the stock camera image is pretty superior to any aftermarket cam you'll buy. i've noticed this first hand unfortunately. you can buy aftermarket cameras with the distance markers, which are nice, but they're CMOS so therefore lower picture quality. check out the thread under my name for installing the backup camera.
cheers!
Bob
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
crazy_g35s
Jul 20, 2015 02:30 PM
