Full Ipod control
Old Mar 2, 2011 | 02:11 AM
PG on G's Avatar
Full Ipod control
I have 07 G35 but keep wondering if there is a way to install 08 iPod integration into 07. Has this been done before??? I just want to be able to control, charge, and view my playlist/library on the screen.
I may talk to parts dept. to see what is needed. I hope it’s just a harness and not expensive module or other components.
Any info will help. Thanks
Old Mar 2, 2011 | 07:26 AM
RemmyZero's Avatar
unfortunately it will likey be more than just a harness required. i'm not sure what trim level you have in your G but likely it would require a complete headunit swap, which also requires changes to the harnesses in the dashboard, so not an easy task. i lament not having full ipod control.
there are other routes obviously, the USAspec adapter, the iSimple adapter (both of which i have for sale in the classifieds - wink wink), the GROM adapter (which requires you to disconnect your XM radio, using a parrot bluetooth module with ipod harness....you have options here....all of which control the ipods fairly well in my opinion. the parrot offers the best/easiest control but does not display on the stereo screen. a quick jaunt through the search engine will definitely reveal more information that you could need im sure.
Old Mar 2, 2011 | 08:15 AM
PG on G's Avatar
I have navi, bluetooth, xm
Old Mar 3, 2011 | 08:38 AM
RemmyZero's Avatar
ok well i want to believe you can add the ipod control but i haven't looked into it much since i have a base model. i know it's been asked before though so maybe there is already a thread here or someone who can help.
Freeman186
Sep 6, 2023 10:07 AM
zcherub
Sep 10, 2015 12:03 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
johnadlertech
Interior
Sep 4, 2015 12:26 PM
