2007 g35x ... what size rim/tire combo
what's going on guys ... i'm looking to get some rims on my g ...
i'm not looking to drop the car anytime and i've heard someone said that 22's will look great on the g if i don't want to drop them ... what to you all think ...
also ... what do you think of the TIS/dub rims?
Check that bolt pattern
Check that bolt pattern. I'm pretty sure Infiniti uses a 5x4.5" pattern not 5x4.25".
Originally Posted by 2007_G35x
the first rim spec:
20X7.5 TIS06 5X4.25 +42
the second rim spec:
20X7.5 TIS07 5X4.25 +30
20X7.5 TIS07 5X4.25 +42
i don't know what bolt pattern infiniti has ... i used the app guide to get the specs for these wheels ... anyone has any idea ...
i'm looking at 19 x 8.5 avarus rims, they are 40mm offset. recommended tire size is 245/40r19. bolt pattern is 5 -114.
35 -40 offset is right on.
you need either new TPMS or you have to use the ones on the current wheels. don't forget that.
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
