Rear alignment/camber kits for lowered G's
Old Jul 23, 2007 | 03:06 PM
g35_6gear's Avatar
Eibach recommends a rear alignment/camber correction kit for their lowering spring kits. For those with their lowering springs installed and who have had an alignment, how far out of spec was the suspension in the rear after lowering.
Old Jul 23, 2007 | 04:40 PM
terrycs's Avatar
It's out of spec, but not by much.
I think I have the data in here somewhere:
https://g35driver.com/forums/v36-brakes-suspension-wheels-tires/138579-my-morning-eibach.html
but in summary:
The camber spec for the rear (non 4WAS) is:
-1.33deg MIN
-0.83deg NOM
-0.33deg MAX
Lowered with best alignment, my camber came in at: -1.7 / -1.4
AFTER kit install, my camber came in at: -0.6 / -0.6
The TOE-IN spec is:
0.00 MIN
0.11" NOM
0.22" MAX
Lowered with best alignment, my toe came in at: 0.11 / 0.26
AFTER kit install, my toe-in came in at 0.15" / 0.12"
Old Jul 23, 2007 | 04:46 PM
g35_6gear's Avatar
https://g35driver.com/forums/v36-brakes-suspension-wheels-tires/159247-data-base-lowered-aftermarket-rims-tires.html
but in summary:
-1.33deg MIN
-0.83deg NOM
-0.33deg MAX
The TOE-IN spec is:
0.00 MIN
0.11" NOM
0.22" MAX
And that's using the Eibach parts?
Old Jul 23, 2007 | 04:59 PM
JMN's Avatar
JMN
What's the best place to buy these kits?
Old Jul 23, 2007 | 05:00 PM
terrycs's Avatar
Yes
Old Jul 23, 2007 | 05:14 PM
G35in305's Avatar
can you link us to the place where you purchased this kit? im having my springs put on soon and im curious
Old Jul 23, 2007 | 05:15 PM
g35_6gear's Avatar
http://www.stillen.com/product.asp?id=EIBALIGN01&c=SU
Old Jul 23, 2007 | 05:51 PM
terrycs's Avatar
Just a note, the G35 camber arm doesn't look like the one in the Stillen catalog.
Picture of camber arm installed:
Picture of toe bolt installed:
Old Jul 23, 2007 | 05:57 PM
shaneotool's Avatar
I would think the rear would not even be out enough to worry about. The fronts will wear out faster because its dropped lower.
Old Jul 23, 2007 | 06:05 PM
terrycs's Avatar
I think so too. But its probably more noticeable in the back only because the rear tire is wider. BTW, still no word on front alignment kit for the 07 sedan from Eibach/SPC.
Old Jul 23, 2007 | 06:56 PM
Extreme G's Avatar
Thanks for the info ..
Old Jul 24, 2007 | 11:17 AM
imminence's Avatar
So we'd want both the camber arm and toe bolt? I've only ordered the camber arm from Stillen, which has been on backorder for weeks.
Old Jul 24, 2007 | 03:17 PM
terrycs's Avatar
You can wait to see what the toe looks like after camber kit installation. You may not need them. The catch is if you do need the toe bolts ... you will need another alignment after installation. Or if they are not very expensive, buy them just in case and sell them if you don't need them.
Old Jul 24, 2007 | 03:58 PM
imminence's Avatar
Eibach lists their alignment kit (PN 5.72260K) as having both camber and toe adjustment. That's the kit I ordered through Stillen. I wonder if Eibach mislabeled their own product.
Old Jul 24, 2007 | 07:16 PM
terrycs's Avatar
I believe you are correct ... Eibach kits both together while SPC sells them a la carte.
