Eibach's Springs for 07 Sedan
Old Sep 2, 2007 | 10:47 PM
ofna's Avatar
I took my car to a local shop to install my Eibach's pro kit springs...bad news they couldn't do it because the coils were so close together that the table crank they used to compress the springs was too big to fit inbetween the coils. So I rented a spring compresser from pepboys and the problem is getting the lowering springs clamped down enough to to install the top bolt. I need some suggestions on how to install these or a shop in San Diego that would be able to do it for me....
Old Sep 2, 2007 | 11:51 PM
terrycs's Avatar
First, please be careful if you're not sure what you are doing.
I've never heard of spring compressors (threaded rods with hooks) not being able to compress the coils enough . You should be using more than one compressor by the way to compress the spings evenly. You also do not need to (or may not even be able to) get into the tightly wound section of the spring. Others in the forum have done this using spring compressors, so it is possible.
Old Sep 3, 2007 | 04:06 AM
prelude555's Avatar
either the shop sucks or they dont have the right tools. i did the spring install with a friend, rented a spring compressor from autozone and it work great. you do however need to compress it alot to mount the top part on so becareful.
reavensf
Sep 17, 2015 11:30 PM
Tukeeg35
18 Inch
Aug 25, 2015 06:45 PM
wuppiedog
Aug 7, 2015 11:16 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Scredeur4
Jul 17, 2015 06:30 AM
