'07/'08 350z springs on an '08 G35?
Old Oct 29, 2007 | 12:27 PM
KCMO's Avatar
Does anyone have the 350z springs installed on their G?
The "Base" coupe weighs 3,339 lbs while the "Grand Touring" convertible weighs 3,600 lbs.
I assume they use the same springs? So they support a range of 3,339 - 3,600 lbs. Do they lower the vehicle any more than the stock G35 sport springs?
(The G35 6MT weighs in at 3,532 lbs btw)
Old Oct 29, 2007 | 12:56 PM
Tiger's Avatar
Bad assumption. Do a little homework before you pick up those springs.
As an example, the 2001 Taurus had approximately 10 unique springs.
Old Oct 29, 2007 | 01:38 PM
KCMO's Avatar
What's the best way to determine this?
Perhaps I'll browse H&R or Eibach's catalogs to see if they use different part numbers for different 350's... I doubt the dealer will look up part numbers for me w/o VINs.
Old Oct 29, 2007 | 01:52 PM
KCMO's Avatar
from H&R's site:
350Z : 2003-up : Sport Spring : 1.3(F) 1.0(R) : 53050 <=(part #)
350Z Roadster Typ Z33 : 2004-up : Sport Spring (22) : 1.0(F) 1.0(R) : 53051 <=(part #)
G35 Coupe 3.5L, 6 cyl : 2003-up : Sport Spring (not AWD) : (22) : 1.1(F) 1.0(R) : 53035 <=(part #)
G35 Sedan 3.5L, 6 cyl, 6MT : 2003-up : Sport Spring (not AWD) : (22) : 1.3(F) 1.2(R) : 53036 <=(part #)
G37 Coupe 3.7L, V6 : 2008-up : Sport Spring (not AWD) : 1.2(F) 1.0(R) : 53030 <=(part #)
* Footnote
(22) Lowering varies by engine size and model
Old Oct 29, 2007 | 02:35 PM
KCMO's Avatar
The "Grand Touring" coupe weighs 3,404 lbs.
It would seem that these springs would already be maybe .5" lower? Then add in the G35's extra 128lbs to lower it down a bit more. Maybe ending in an 'OEM' .75" drop?
Can the springs even be used across platforms?
I know the older G35 sedans could use G35 coupe/350z springs.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
