Can G35 Sport tires be rotated?
Old Aug 27, 2008 | 09:56 AM
JMZ_blkobsidian's Avatar
I know the front and rear are different sizes, but if left-to-right rotation possible, or no?
Do 'directional' tires mean that the inside and outside are specified, or the direction of rolling is fixed?
Old Aug 27, 2008 | 10:25 AM
sredish's Avatar
no. the fronts are narrower than the rear and the offset of the wheel is different. rotating is basically moving the front to the rear and you can't do that with the staggered wheel/tire setup.
Directional tires have a "one-way" tread pattern that are optimized for the direction the tires rotate on the car. They must therefore be mounted on either the left or right side. Little arrows or triangles on the sidewall indicate which way the tire is supposed to turn. The tread blocks and grooves are angled to optimize handling. They also do a good job of channeling water out from under the tire on wet surfaces to reduce hydroplaning and improve wet traction. Directional tires can be rotated front-to-rear (if same size, of course) but cannot be rotated side-to-side.
Old Aug 27, 2008 | 10:27 AM
LiquidGx's Avatar
Search button = https://g35driver.com/forums/tech-07...-rotation.html
Old Aug 27, 2008 | 11:34 AM
IvoryPearl07G's Avatar
you cannot go from front to rear....but you can however swap sides(dismounting from rims and remounting on opposing side) this helps people with camber issues
Old Aug 27, 2008 | 12:07 PM
dopey's Avatar
just as an FYI (you may know this already) the stock RE050A on the S is not directional. It is assymetric though, so they have a dedicated outside and inside tread. So no need to unmount/remount then on the rims on opposing sides if for some reason you need them rotated that way.
sredish's Avatar
are the stock tires not directional? I got rid of em so fast, I never paid attention to it....
Old Aug 27, 2008 | 12:10 PM
mal_TX's Avatar
the service manual says they are directional and cannot be rotated.
Old Aug 27, 2008 | 12:45 PM
coolguy8157's Avatar
No...they cannot be rotated...
Old Aug 27, 2008 | 02:39 PM
dopey's Avatar
look at the tire.
http://www.tirerack.com/tires/BigPic...Potenza+RE050A
Note the lack of directional rotation arrows.
Also note that it says "outside" on the tire.
the RE050A is NOT directional. Most assymmetric tires are not directional. There're maybe one or two tires that are both assymmetric and directional and the RE050As is not one of them.
Old Aug 27, 2008 | 02:44 PM
silverG2007's Avatar
Unless your VLSD isn't working, or your alignment is off, rotating from left to right won't make a difference.
Or, if you drive your car in nascar and love left turns.
Old Aug 27, 2008 | 02:45 PM
dopey's Avatar
Right, whether or not it's worth the rotation is a separate point (and in most cases it's not). But the 050As are not directional. The non asymmetric 050s are:
http://www.tirerack.com/tires/BigPic...=Potenza+RE050
Old Aug 28, 2008 | 09:08 AM
snowcrossmxz's Avatar
drive it till they are bald, trade it in
Old Aug 28, 2008 | 09:11 AM
G35Now!'s Avatar
Moderation-free
Originally Posted by dopey
look at the tire.
This is correct - the stock sport Bridgestones are not directional, and can be rotated side-to-side without dismounting the tire.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
