Please - quick help on offset/tire size - time sensitive
Old Jan 29, 2009 | 11:59 PM
DRVRSWNTD's Avatar
I have an opportunity to buy a steal of a set of wheels, but they arent my preferred size or setup, I just need to confirm that they will fit:
Stock suspension (for now) G35xs 2008
wheel is a 19x9 +40et
Looked at Terrycs page, and saw a few 9" wide fronts with lower offsets, or 8.5 with close to stock offset, but nothing similar to this.
I dont usually try to stray too far from sotck ET as I dont want bearing issues, and I dont need to be "hella flush". But adding an inch and a half to the wheel from stock, and an additional half inch on the inside, ssems to be too large.
Can anyone confirm that this would fit? Need to know in like the next 30 minutes or so
Old Jan 30, 2009 | 12:05 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
They will fit PERFECTLY fine. Definitely not too large of an upgrade.
-GP-
Old Jan 30, 2009 | 12:06 AM
DRVRSWNTD's Avatar
thank you, buying them now
Old Jan 30, 2009 | 12:29 AM
G35xQX1's Avatar
just to ease your mind...im assuming that you bought the wheels already, but you will be perfectly fine
Old Jan 30, 2009 | 11:20 AM
DRVRSWNTD's Avatar
Thanks, I did order them last night - Advan model 5 in 19x9 +40 $1K for all four
I was planning on some cheaper summer wheels for our crappy chicago roads, but for $250 per, I can pamper some advans
chinee
Jun 10, 2024 07:48 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
