Brake light on while accelerating?
Old Jun 3, 2009 | 07:09 PM
Thrillryder23's Avatar
So for some reason when I accelerate the red BRAKE light goes on in my car - the slip light won't though and there is absolutely no slippage when this happens.
It's turning on pretty consistently now whenever I accelerate - mostly a hard accelerate but it has happened sometimes when I would only apply maybe 50% or so of the gas (even less sometimes). I can't pinpoint the cause of the issue because the Brake light is turning more and more consistently as the more I keep driving the car but I don't feel any braking to any of the wheels when this happen - I just continue to accelerate.
The light goes away maybe a second or two after the RPMs have settled. The only aftermarket mod I have in my car is the K&N short ram intake. I've had the intake in for about 4-5 months and the mileage on the intake is nearing 7k I believe. I haven't re-oiled the filter cones yet (heard that has to be done every 20k) and this brake light issue was never an issue up until a few weeks ago and its been pretty consistent ever since.
Any ideas?
Old Jun 3, 2009 | 07:41 PM
greg_atlanta's Avatar
2008 G35 Journey Sedan no sunroof
You mean the emergency brake light on the dash? Check the brake fluid level.
Old Jun 3, 2009 | 08:11 PM
AesonVirus's Avatar
+1
Do a search for this in the tech section... lots of threads on this.
Even if the fluid looks full, add just a tad to top it off. As your pads wear and the calipers come further out, the fluid drops to a point where acceleration or cornering fires off the low fluid warning.
Old Jun 4, 2009 | 01:51 AM
vinceypoo's Avatar
i have the exact same issue thats been happening lately (2 weeks ago). the car feels exactly the same but Brake light comes up when you push about alittle more than 50% throttle and VDC OFF and SLIP will flash up if im pushing 75%+ . 07 sedan with 21k miles . keep us posted
Old Jun 4, 2009 | 02:05 AM
tg1234's Avatar
Get ready to replace your pads.
Old Aug 14, 2009 | 06:15 AM
Matchstickman60's Avatar
so did anyone find out what is causing this problem because this just happen to me today. Every time I go over 5k the brake light just blinks and go away
Old Aug 14, 2009 | 06:57 AM
AesonVirus's Avatar
Low brake fluid. Check your fluid level and see what's left on your pads.
Old Aug 14, 2009 | 04:30 PM
kregg's Avatar
Noone believes you AV
Old Aug 14, 2009 | 07:48 PM
GEE35FX's Avatar
+1^^^,,, people don't know how to use the SEARCH feature
Old Aug 17, 2009 | 07:35 PM
AesonVirus's Avatar
Yeah, Wayne and I are starting to sound like broken records in all these "brake light" threads.
Old Aug 17, 2009 | 09:01 PM
GEE35FX's Avatar
So true
I think it is time a sticky was put on this problem and the common cures.
Old Aug 17, 2009 | 09:15 PM
speedracerg35's Avatar
if the brake fluid is low and your pads need to be replaced, replace the pads first. if you top off the brake fluid, then replace the pads, you will overflow the brake reservoir when you push in the pistons on the calipers.
Old Aug 17, 2009 | 09:25 PM
GEE35FX's Avatar
Absolutely, good point, that was said in another post, definitely check your pads first.
Old Aug 21, 2009 | 03:24 PM
dopey's Avatar
I had this problem. They had to replace the parking brake switch to fix it.
Update: guess what, replacing the parking brake switch didn't work. After some spirited driving on the way home from work, it's doing it again. The dealer had my car from Tues-Fri and they couldn't figure out what to do other than replace the parking brake switch. I just had my 30k service and I have over 50% of my brake pads left. How is it that they don't know about topping off the brake fluid? Has anyone had the experience that their dealers seem clueless about this problem? I'm going in Monday and insisting that they top off the fluid to see if it solves the problem.
Hasanbaloch
Feb 29, 2024 08:45 PM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
mike730
Jan 12, 2018 04:25 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
Lsantana757
Jul 20, 2015 09:08 AM
