Decision time for Springs!
Old Nov 8, 2009 | 04:35 PM
  #151
pfarmer's Avatar
Originally Posted by kregg
I lined up the rear wheel centerlines in paint. Looks like OEM is a tad higher, and they wrapped the wheels in rubber bands for their pic . I am bone stock.
So yours is an X and the picture is a ..................
There is a .6 inch difference.
Old Nov 11, 2009 | 11:28 PM
  #152
remo's Avatar
Originally Posted by AesonVirus
Yeah, my toe is still not perfect. I'm gonna have to ask them to dial it in a bit more on my next alignment.
They did change it from -0.08 to 0.04, so that is a HUGE difference. Should I be shooting for 0.00 as well?
My front camber is only barely out of spec, but the rear definitely will benefit from a kit. That's sitting at -2.3*. Looks great, but that's gonna smoke tires quickly too. I do want a bit more neg camber than what spec calls for, but I don't want to go overboard as well.
I dropped the car for looks as well as for the improved handling. Bringing the camber right back to spec does away with some of that improved handling.
I'm trying to find a nice balance between the two.
So, did you install alignment kit?
Old Nov 30, 2009 | 02:29 PM
  #153
hobbs's Avatar
alignment kit?
is Eibach align. kit from Tirerack ok to use? Manufacturer Part # is 5.72265K. I have 08 xS and thinking of getting the spring and the align kit at the same time. I understand that I may not need the fronts and I will just order the rears. Which one should I get? camber +/- 3.00 is $29 and +/- 4.00 is $179
Old Nov 30, 2009 | 04:06 PM
  #154
InTgr8r's Avatar
Staff ALUMNI (retired)
Scale may be off a little.
The 37 wheel looks larger in DIA
Old Nov 30, 2009 | 04:37 PM
  #155
soundmike's Avatar
It does seem off, notice the difference in curvature of the gap between door and panel. Also, notice how much higher the side rockers are on the right photo.
Old Feb 11, 2010 | 04:37 PM
  #156
qbturbo's Avatar
Has anyone tried the G37x coupe springs on their G37x Sedan? Since the coupe weighs only about 40lbs more that the sedan, wouldn't these springs ride better than the rwd sedan springs?
Old Feb 11, 2010 | 07:28 PM
  #157
kregg's Avatar
Sorry I didnt respond to you guys (soundmike and integr8r) sooner, I didnt get a notice..... if you guys still care... its been awhile .... i think I used the wheel well to set the scale (overlayed them and got them to match in size). The photo on the right is my car, stock and unchopped.... I think the differences you are seeing are from Infiniti's chopping. But dunno really, just guessing..... The rocker would have to be higher on mine since they slapped 15 series tires on the wheel, otherwise they would be floating in air or the gap would be bigger.
Old Feb 25, 2010 | 02:31 PM
  #158
bsowhat1's Avatar
I was thinking the same thing. Weight wise the G37x coupe is closer to the G35/35x sedan than to the RWD sedan.
Have any of the Eibach owners noticed a choppy ride or frequent bottoming out? I am worried that the stock struts would not be sufficient for the lowered ride height. I lowered our 04 G35 coupe on TEIN 350Z H-techs but found the that the car would blow through suspension travel on deep bumps. I ended up installing Tokico D spec struts to increase the dampening for the stiffer, lower springs.
Old Feb 25, 2010 | 04:18 PM
  #159
soundmike's Avatar
^ about the bottoming out, what does it feel like to you?
Reason i ask is that i've had progressive springs on cars before the G, and because of it's nature, the softer part compresses much faster then it tightens up -- depending on the variables (i.e. road surface, turn, speed, etc.) it did feel like it was bottoming out at times, but really it wasn't. However, it was more pronounced on used dampers vs. aftermarket ones.
Old Feb 25, 2010 | 05:34 PM
  #160
bsowhat1's Avatar
Bottoming = rear seat passenger head hits the ceiling.
DimQ
Aug 10, 2015 11:38 AM
andresito7
Aug 1, 2015 04:53 AM
