Akibono BBK Stock G35S Wheels
Old Nov 11, 2009 | 12:22 PM
Mainer's Avatar
Does anyone know if Akibono BBK will fit under my stock 18" rims on my 07
G35S Sedan? Will I need a spacer? Talked to seller he said sometimes the BBK fits sometimes it does not!
Old Nov 11, 2009 | 12:44 PM
04G35NYC's Avatar
you will need spacers or get G37 wheels and you won't have problem.
Old Nov 11, 2009 | 02:03 PM
Austin713's Avatar
how much bigger are the rotors on the Akimbo kit than the stock G35S rotors??
Old Nov 11, 2009 | 02:08 PM
soundmike's Avatar
Here you go. I say you probably won't be able to fit it without (a) a wide enough spacer and (b) relocating the wheel weights.
http://gshack.org/?p=118
G35S Rotors:
F: 12.99" x 1.26"
R: 12.99" x 0.630"
Akebono:
F: 13.98" x 1.26"
R: 13.78" x 0.787"
Old Nov 11, 2009 | 06:45 PM
Mainer's Avatar
Akibono RR
will 15mm spacers do or how can I figure it out? and do I need front and rear spacers? Fronts 225/18 Rear 245/18
Old Nov 11, 2009 | 06:46 PM
Mainer's Avatar
Akebono RR weights
Where do I need to move the weights (probably a stupid question)?
Old Nov 11, 2009 | 08:02 PM
soundmike's Avatar
My OEM's are in storage so i can't measure it for you. The images i posted on my site should give you an idea of spacers and wheel weight placement. If you need further insight, i suggest downloading Coz's template (CZP on the marketplace).
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
jimNC
Jul 25, 2015 05:47 AM
laksjd84
Jul 24, 2015 05:12 PM
realtalk21
Jul 20, 2015 09:07 AM
