Akebono brakes fit 2007 G35S Sedan
Jan 23, 2010 | 06:18 AM
  #31
Get the lines from G37S sedans?
Problem solved! haha
Reply 0
Jan 23, 2010 | 06:34 AM
  #32
LOL, thanks .
Reply 0
Apr 6, 2012 | 09:23 PM
  #33
So let me get this straight, The minimum is 15mm in your post but according this thread http://gshack.org/?p=174 the minimum is 5mm. which one is right?
Reply 0
Apr 6, 2012 | 09:53 PM
  #34
The narrower front Sport front wheel will need a much thicker spacer to clear. The 5mm i referred to was for the wider rear wheel to fit on the front.
Reply 0
Apr 6, 2012 | 09:58 PM
  #35
Quote: The narrower front Sport front wheel will need a much thicker spacer to clear. The 5mm i referred to was for the wider rear wheel to fit on the front.
Oh I see, thanks for clearing that up. So using the less wider front sport wheel, 15mm is the least you can put right? By the way thanks for the fast reply.
Reply 0
