Can i buy just a rear aftermarket sway bar?
Am I not seeing it? Is there no company that sells just a rear aftermarket sway bar? I know Hotckis and Stillen has kits that include both front and rear.
Also....
If you decide to buy a f&r set, and just use just the rear;
Make sure you select something that has a min setting close to OE,
otherwise you may end up with a really twitchy rear end.
A min setting somewhere around 110% should match up pretty good.
Rear Sway Bar 27mm (Ø1.063") Hollow 3 Way Adjustable
+120, 175, 250% Stiffer than Stock G37
+5, 30, 65% Stiffer than stock G37S
+50, 90, 145% Stiffer than stock G35S
Did anyone ever try an OE S bar on an X?
the G37S & G35S give you two different settings to try.
I'd be inclined to start with the G35S bar so that you don't over match the front OE.
can you please elaborate? who is motordyne and how can we get this going?
Here you go my friend -
http://myg37.com/forums/brakes-suspe...amplified.html
Rear sway bar can be purchased separately for $195 but Lou is having an introductory sale price so it should be even cheaper.
Check out this thread.
Motordyne making SBs for 1st gen X
goto post 38
https://g35driver.com/forums/g35-sed...2-sways-x.html
goto post 38
