Akebono front calipers
@ elayman Not sure. So if I put 6 piston calipers up front I would have to get 1.5 piston calipers on the back?
I think the sizes of rotors factor into the bias so you can possibly run 6piston all around just have tiny rotors in the rear. Not sure if the 6pistons can fit on a small rotor though
brake bias is calculated using force..the size of the rotors is primarily for heat dispersion i think
ah good call.. yah then i doubt you can run 6 piston all around without having some weird braking going on
the brake bias takes into consideration weight transfer from rear to front while braking you have greater traction in the front so greater braking force can be applied before the wheels lose grip.
so if you have the equal force on the front and rear while braking the rear will get really loose kinda like pulling the e-brake every time you stop.
so your car will look great..but will be unsafe to drive.
