Akebono BBK off FX
Old Apr 29, 2010 | 03:40 AM
a17z's Avatar
Akebono BBK off FX
My understanding is that the FX has the same setup as the G37s. All I need are the calipers/pads/rotors. The components of the hardware kit, brake pins and clips would be already assembled with the calipers. Dust shields are optional. Is that all correct to do a straight swap? Do I also need the brake lines and banjo bolts?
Old Apr 29, 2010 | 03:59 AM
E-Ticket Ride's Avatar
A quick peek at infiniti.com showed only the FX50 has the 4 piston/2 piston 14" brakes.
The FX35 has the smaller 13/12" setup.
http://www.infinitiusa.com/fx/specs-options
Old Apr 29, 2010 | 07:11 AM
soundmike's Avatar
If you're getting the parts new from the dealership or elsewhere, the caliper only comes with... the calipers. The pins, clips and hardware kit are sold separately.
You will also need the banjo bolts. The OEM one, assuming you have a 2nd Gen G, is too long (or short, can't remember).
Old Apr 29, 2010 | 10:44 AM
STRAFEAuto's Avatar
Strafe has 2 piece rotors and rotor kit for 1750 front and rear. contact sales@strafeautomotive.com
Old Apr 29, 2010 | 12:42 PM
a17z's Avatar
Clarification. I'm pulling the brakes off a FX50. So I just want to make sure I don't miss anything. Thanks guys.
Old Jul 1, 2010 | 02:59 AM
a17z's Avatar
FYI, rear rotors and backing plates are different. The overall diameter is the same but the ebrake drum is larger on the FX50.
Old Jul 1, 2010 | 03:46 PM
Q8y_drifter's Avatar
Just get all the bolts and pins and everything from the calipers so you don't worry about missing anything later.
seagrasser
May 3, 2022 09:43 AM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
w4kj4k
Other Cars
Mar 6, 2016 08:06 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
