stock sedan s droped on eibach springs
Old Jun 1, 2010 | 05:00 PM
firozu's Avatar
I already did the drop and i took it for an alignment the guy at pepboys told me i need a camber kit for the front to get the alignment right....i have the camber for the back but not the front...is that true? Also where would i get this?
Old Jun 1, 2010 | 08:58 PM
firozu's Avatar
anyone?
Old Jun 1, 2010 | 09:04 PM
davidxu's Avatar
marketplace.
Old Jun 1, 2010 | 09:05 PM
mishmosh's Avatar
You could be a little under or over the limit for negative camber. Some shops will finagle the strut bolts to tweak it but I doubt pepboys would go to the trouble.
Old Jun 1, 2010 | 09:14 PM
firozu's Avatar
kk so u think i hsould just leave it then?? cause the arms i c are like almost 400.....and im honestly kinda tired of working on my car after the suspension upgrade.....took quite a while as well. will put pix up soon
Old Jun 2, 2010 | 11:53 AM
firozu's Avatar
So should I get the arms or just leave it?
Old Jun 2, 2010 | 03:46 PM
terrycs's Avatar
Do you want your tires to last longer? Do you hate dealing with side to side rotation? If so, you'll want the new upper control arms. It shouldn't take very long to make up the cost for the arms. I think you should be able to find them for less $$.
Old Jun 2, 2010 | 04:02 PM
LightsOut's Avatar
SIETESG
post up your alignment specs?
having more camber than normal shouldn't be to bad, its the toe that matters. and I bet your toe is in spec.
Old Jun 2, 2010 | 09:20 PM
firozu's Avatar
i ont have the alignment specs but ill try to get them
Old Jun 2, 2010 | 09:30 PM
firozu's Avatar
terrycs you had the same car dropped on the same springs did u get the front camber arms???
Old Jun 2, 2010 | 09:36 PM
firozu's Avatar
also where is the cheapest i can get them?
Old Jun 3, 2010 | 04:40 PM
terrycs's Avatar
Yes, I have the camber arms front and back now. Let me put tire wear into perspective ...
I bought 4 brand new tires when I got my wheels. At the same time, I installed rear camber kit (because the front kit was not available). Since then, I've already gone through my first pair of front tires due to camber wear ... and yet I'm still on the original pair of rear tires.
I also got the front camber kit when I replaced my front tires. I always read about people saying added camber in front is OK for daily driving, but based on my personal experience, I would always recommend getting the front camber kit.
Old Jun 4, 2010 | 06:41 PM
firozu's Avatar
which camber kit for the front did u happen to buy?
Old Jun 5, 2010 | 01:27 AM
terrycs's Avatar
SPC for both front and rear.
Old Jun 7, 2010 | 03:37 PM
firozu's Avatar
dang those are super expensive tho...are there any around the 200 doller price range?
