Car Rims
Old Jun 29, 2010 | 09:20 PM
floyd72889's Avatar
Car Rims
I am looking at buying some 20" rims for my 2007 G35 Sedan and i was wondering if i needed to get any kind of offset the rims are 20x7.5?
Thank you in Advance.
Old Jun 29, 2010 | 09:22 PM
jayk's Avatar
20x7.5???
tall and skinny.
Old Jun 29, 2010 | 09:26 PM
floyd72889's Avatar
Yea what size would you Suggest????
Old Jun 29, 2010 | 09:50 PM
blnewt's Avatar
I've got 20x8" wheels~245/35/20 tires fit perfectly on them, the 7.5" rims would be a bit too narrow for a good fit. Also the 245/35/20s are the same diameter as the stock tires so you'll have no speedo or traction control issues.
My rims are stock offsets BTW.
Old Jun 29, 2010 | 11:31 PM
NBYOND's Avatar
I'd go with at least 20x8.5
Old Jun 30, 2010 | 12:06 AM
supracrazy's Avatar
Please don't...
If your going to get big rims on your car, at least get them wider then stock. I would go with a 20x9+20 all around.
Old Jun 30, 2010 | 12:16 AM
typesblkura's Avatar
^^^ +1
Old Jun 30, 2010 | 01:16 AM
lefizzet's Avatar
I'm running 20x8.5 +38 and that could use 15mm spacers to make them flush in the front. In the rear 20x10 +43 are perfectly flush with like -.03 camber
Old Jun 30, 2010 | 10:50 AM
suby01's Avatar
i have 19x9.5 + 38 all around.
for the X you should look at 9-9.5 with a +30- +40 offset.
Old Jun 30, 2010 | 12:49 PM
lefizzet's Avatar
I'm running staggered on an X perfectly fine, just do research and get the correct tires
Old Jun 30, 2010 | 03:26 PM
terrycs's Avatar
Check out some examples here if you are also planning to lower your car:
https://g35driver.com/forums/v36-bra...ims-tires.html
Old Dec 22, 2010 | 12:12 AM
snoopdoog's Avatar
OK I looked at a few websites and the people around here are also saying they are high offsets aka 35-40 and this car rims website doesn't have g35 but all similar models are high offsets.
Old Dec 22, 2010 | 12:40 AM
kennymo's Avatar
please dont even look at rims on that website...
Old Dec 22, 2010 | 02:03 AM
bluedevils95's Avatar
You should do what i did and just get any rim you like. If it doesn't fit, make the car fit the rims. hahaha
Old Dec 22, 2010 | 02:41 AM
ChinkyChoy's Avatar
i m running 19x8.5 +25 all around on my X
but i am also dropped on BC Coilovers
