DIY Brake Judder TSB today
Old Feb 2, 2012 | 03:58 PM
G35power's Avatar
Ok Dealer is telling me that Infiniti Extended warranty doesn't cover the New rotors and they cannot submitted the claim for this TSB to replace dust shields for the front brakes. Because TSB requires the failed part number, since failed part is rotors, extended warranty doesn't cover new rotors or machined them.
So that why they cannot replace only dust shields with this TSB. If dust shield cause the rotors to fail due to heat, why they expect me to pay for new rotors or to machined them? I called Infiniti Corporate and filed the case. Hopefully people from corporate will give ok. My car is 2007 with 41k miles
Old Feb 10, 2012 | 10:03 PM
G35power's Avatar
Took my car for inspection today, yes it has problem. Got a call later on they, Denying work because extended warranty doesn’t won’t to pay and they didn’t approved good fill. Let’s see what corporate will say!
Old May 13, 2012 | 05:23 PM
StPete08G354D's Avatar
Call BS on them. The TSB states, "Inspect the front brake rotor to determine if resurfacing is possible or if replacement is necessary." Take a copy of the TSB with you. My dealer said that it was covered.
http://www.infinitig37.com/TSB/1SJ14.pdf
Old Jun 5, 2012 | 12:56 PM
Dirty K's Avatar
What is the "brake pad kit" listed on the TSB? New pads?
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Jiggerjuice
Oct 5, 2015 02:33 PM
linedr89
Aug 17, 2015 05:11 PM
Jussaku
Aug 4, 2015 12:45 PM
Lsantana757
Jul 20, 2015 09:08 AM
