19x8.5+34
Old Jan 19, 2011 | 09:58 PM
zoop425's Avatar
19x8.5+34
Hey guys Im looking into the verrstoen ES 1.1.2 (BBS mesh style) rims. Im and x and don't want to go staggered.. they don't make this size for our bolt pattern and center bore but I asked to see if they might and this will help for further wheel selection. I want to go wider than stock (hence the 8.5) and I dont plan on dropping more than an inch in the future (hence the weak offsets) so, just want to check, will this size work in all four corners with no problems?
Old Jan 19, 2011 | 10:17 PM
ChinkyChoy's Avatar
i m pretty sure you will be fine because i m on coils and i am running 19X8.5 +25
all around
no rubbing or anything
if anything you might need spacers and thats it.
Old Jan 19, 2011 | 11:12 PM
zoop425's Avatar
Ok good.. I might be getting these then as the guy from varrstoen said he could give me a deal.. but they are only in gunmetal.. that means I will have to get the powdercoated black!
Old Jan 20, 2011 | 08:02 AM
soundmike's Avatar
You'll be fine. I run 19x8.5 +35 w/ 255/40 tires. No rub before or after the drop (CO's)
goldy213
Aug 30, 2011 06:21 PM
