KYB Struts/Shocks for G35x
Old Oct 8, 2011 | 04:31 AM
harp00n's Avatar
no info for now (as they will be shipped to bo_6 only in a month)
but KYB Gr-2 (aka Excel-G) are known to be 10% stiffer than stock struts to compensate the spring wear at 60K-100K, when people usually change their struts.
Old Oct 8, 2011 | 06:21 AM
KBTOPDOG's Avatar
Ordered the KYB rears for my 05x from here and they fit.http://www.discountautoshocks.com/
I dont think anyone has the fronts besides the dealer., please let me know if anyone has made them. FYI they are definitely a lot stiffer than OEM.
Old Oct 8, 2011 | 02:06 PM
mishmosh's Avatar
So being 10% stiffer, they should be good paired with Eibach springs?
Old Oct 10, 2011 | 12:54 PM
kayveeee's Avatar
So KYB are the only shocks/struts made for the G35X? Any other site you can purchase other then tirerack, and discountautoshocks?
Old Oct 18, 2011 | 01:52 AM
2006g35xsilver's Avatar
I found cheapest KYB GR2 for 2006 G35X at usautoparts.net. Not sure about newer models. They are considered oem replacements, not aftermarket upgrades. They also come only with the bare strut assembly and new top bolt. If any of your other parts need replacement, boots, mounts, insulators are extra. But, it is a pretty easy install, just slide out the old one and slide in the new one, depending on how easy you get the old one off.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AJC128
Nov 1, 2015 11:55 AM
Claudiu
Sep 26, 2015 01:04 PM
Claudiu
Sep 24, 2015 01:12 PM
